06-22-2015, 08:16 AM
Nav light wiring
What kind of wire should I use to power wing tip lights?
06-22-2015, 09:20 AM
My AeroLED's just specified Tefzel wires. Some manufactures recommend shielded wire. I would install what is recommended by the manufacturer.
06-22-2015, 09:31 AM
I used Tefzel 18 ga. for my wing tip lights. 3 wires
for nav, strobe and sync. signals
06-22-2015, 09:32 AM
Any light kit you purchase should come with instructions.
AeroLEDs specify shielded Tefzel wire with the shield grounded at both ends. You can download the instructions from their website.
If you are installing the old style lights (not LED), non-shielded would be fine.
Ray
06-22-2015, 09:47 AM
Should an LED strobe power wires be a twisted pare with the ground going all the way to the forest O tabs?
06-22-2015, 10:22 AM
It depends on which LED strobes you are using.
Whelen LED strobes, and actually all Whelen LED lights which includes NAV, strobes, and landing lights, require no shielding and nothing to run back to ground for noise. As others have said, you should check with the wiring instructions for the specific lights your installing.
Kahuna
6A, S8 ,
Gold Hill, NC25
06-22-2015, 11:17 AM
Twisting power/ground isn't a bad idea and can't hurt.
Consider putting a ground terminal block somewhere close to the wing root (under the seat in a 7) and run an 18g wire from there to the FOT to reduce the number of ground wires going to the panel.
Some tips from a site:
http://www.experimentalaircraft.info...wer-ground.php
Ray
