06-16-2015, 10:59 AM
Battery + Firewall Pass Through
Looking to understand what RV-10 builders are using for the battery + firewall pass through. I believe most are using some sort of firewall mounted device but not sure what that is. I guess same goes for the negative side.
E
06-16-2015, 11:05 AM
Firewall ground
I am using the ground bus on my rv4.
06-16-2015, 11:06 AM
Link
06-16-2015, 11:22 AM
Check these out
Steve Hamer
RV-6
Eagle, ID
06-16-2015, 11:38 AM
Senior Curmudgeon
I just used a snap bushing in the hole provided, sealed with high temp sealant.
Look at the build manual.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
06-16-2015, 12:04 PM
the Summitt Racing or Jeg's battery firewall pass thrus work really well. The advantage over just running it thru a grommet is that you have a terminal that the wires can be taken on and off of or added to.
06-16-2015, 02:01 PM
Try these!
This company has been excellent to work with. Check out this 550A power bushing...
https://www.vtewarehouse.com/content...r_bushings.php
They also have 1/4" tab forests...
Also way cheaper than summit racing...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
06-16-2015, 02:56 PM
I do like Mike. The hole is already there and the wire almost fills it.
Actual repeat offender.
06-16-2015, 03:50 PM
I plan on using the VPX and was going to use the firewall mounted pass-through as the termination point for the battery + coming off the rear mounted contactor. I could then power the VPX from there. If I pass the cable through the firewall I will then need to pass one back to the VPX. I guess I could go to the VPX first then through he firewall.
E
06-16-2015, 04:24 PM
San Diego Marine Exchange
Ethan,
I used what a lot of other guys used....
https://www.bluesea.com/products/cat...ugh_Connectors
You can walk into San Diego Marine Exchange down on Shelter Island and grab one. They usually have them in stock.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system!
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
