Old 06-10-2015, 09:10 AM
jsenft jsenft is offline
Default Headset Question
Before I take off my wings and check my headset connections, I am hoping someone can help shed some light on my issue.
I have one old Softcomm headset that works perfect on the pilot side. I think it is stereo, by looking at the plugs.
I have two new Sennheiser S1 ANR headsets. The co-pilot side everything works perfect. On the pilot side, I cannot hear myself when I talk. If I talk on the pilot side, I can hear it on the co-pilot side. If I talk on the co-pilot side, I can hear it just fine on the pilot side. Flipping between stereo and Mono did not change any behavior. The old Softcomm headset just works fine on the pilot?s side.
Note: I do have the optional video jack install on the co-pilot side
Old 06-10-2015, 09:44 AM
664781 664781 is offline
Default Wiring
Get a schematic and check your wiring. Mine had 2 wires going to the wrong pins.
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 06-11-2015, 04:48 PM
dinowal dinowal is offline
Default Wiring
Hi JSENFT, Look up the revision to page 31B-17 posted 03/18/15, for the wiring to the headset sockets. This is now the correct way to wire them. If you wired yours according to the original drawing there are several wires not connecting as they should.The system works, but not properly..
Correcting the wiring does involve wing removal unfortunately,
Good luck, cheers, DEAN
Old 06-22-2015, 10:02 AM
Problem Solved. It was a loose green wire on the pilot side.
Old 06-23-2015, 07:53 AM
rfchisholm rfchisholm is offline
Default Great!
Now you can fly to 61C ... and we can try out the new headsets!!
Ronald F. Chisholm
RV-12; N439CH - Flying!
RV grinnin'!
2020 dues paid!
