06-09-2015, 03:16 PM
Blind Rivet Problem
I need to set 8 blind rivets in a confined location and I need a rivet tool with a pulling head 2" or less and all I have found measure 3" including the handle.
I have tried a swivel head puller but it was also too long.
My available riveters would pull at about 45 degs.
Does anyone have any tricks or know of a tool source I could try?
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
06-09-2015, 03:31 PM
I had a similar issue when installing the Vans ELT bracket. The bottom row of blind rivets could not be pulled so I used #6 screws with nuts instead.
Ray
06-09-2015, 03:32 PM
Tool
The PRP-26A close quarter tool is about 2" from tip to handle. Maybe someone near has one you can borrow. Kinda pricey tool.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
06-09-2015, 03:49 PM
This tool might help: http://www.averytools.com/prodinfo.asp?number=5012
You can also try using a piece of AEX wedge to offset the rivet puller.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
06-09-2015, 03:50 PM
Glenn Wilkinson
Could try grinding the puller end piece. I've been able to get about 10-15 degrees that way. Might be enough if you grind the handle a bit as well. Have several modifed $10 stanley pullers.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
06-09-2015, 03:58 PM
I had a similar problem, go here to see how I solved it (page 4 I think has a photo). Took me a few months of head scratching to figure this one out.
http://www.vansairforce.com/communit...t=75023&page=4
Glenn Wilkinson
06-09-2015, 09:23 PM
Can you post a picture of what you are trying to rivet? Someone here might have a good way to do it.
RV 7
06-10-2015, 07:57 AM
yes me too on the elt bracket, incert rivet, bend nail use standard puller, no problem
06-10-2015, 07:49 PM
Pic?
Need pictures to help..also, where are you located? I have offset cherrymax pullers that get in small places, and there are other options perhaps if you can better describe.
Bill E.
RV-4/N76WE
8A7 / Advance NC
06-11-2015, 12:17 AM
When I get to the hanger this weekend I'll get some pictures of what I am trying to do and I'm sure everyone can get a better idea about what I have written.
Oh, I have also ordered that part from Avery Tool suggested on an earlier post....maybe it will help.
Glenn
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
