Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 06-08-2015, 12:52 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default ADS-B Antenna Splitter for dual ADS-B IN?
Has anyone by any chance installed dual ADS-B IN receivers and used an antenna splitter to feed them? I am considering installing both a Dynon SV-ADSB-470 and a Garmin GDL-39R and would like to avoid installing two receiver antennas if possible. Any RF guys out there have an opinion?
And because inquiring minds want to know - I have both a Dynon Skyview and a Garmin GDU-375 in the panel which, for various reasons, I would like to receive ADS-B IN. Ah if only there were interface standards . . . . . .
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 06-08-2015, 01:32 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Dan,
A splitter should work fine. Just make sure you get a quality one that covers both 978MHz and 1090MHz.
The downside to using a splitter is the signal loss. You can't split a signal without giving half the power to each device, so you lose some range when you do this.
A $20 transponder antenna is going to cost a lot less than a good splitter.
--Ian Jordan
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 06-08-2015, 01:37 PM
Default Drilling Holes
Originally Posted by dynonsupport View Post
Dan,
--Ian Jordan
Thanks for the response - good info.
The issue for me isn't the cost of the antenna or splitter, I just would like to avoid poking two more holes in the airframe and running two cables.
Dan Langhout
Old 06-08-2015, 01:54 PM
A lot of people have had good success with putting the little antennas that come with the unit inside the airplane (just not behind metal). I have them on my fiberglass doorposts (-10) and they work fine.
Yes, I think the Dynon will only work with the Dynon, Garmin only with the Garmin. Not universally true - GRT and WingX will work with a number of different ADSB-in boxes.
