Old 05-08-2014, 08:03 AM
stabilizer tips stabilizer tips is offline
[IMG][/IMG]
Old 10-01-2014, 08:01 AM
I currently have another batch or stabilizer tips in stock and ready to ship.
Contact me if you are interested.
I also have a few sets of factory seconds available.
youngoak@yahoo.com
149.95 + shipping
factory seconds, 125.00 free shipping to the lower 48 of the USA
Old 12-05-2014, 08:09 AM
Default holiday special
$125.00 Holiday special on my horizontal stabilizer tip kit while supplies last.
The special will also include free shipping to the lower 48 of the USA.
Old 02-06-2015, 09:53 AM
Give your RV-12 the finishing touch with a Tip Kit. Cover the unfinished ends and give your plane the look it deserves.
Old 04-30-2015, 02:55 PM
More tip kits in stock get yours today!!
Old 05-31-2015, 07:01 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default Aerodynamic benefit?
Today I worked on the stabilator tips which I purchased from Clint.
I am quite impressed how nicely the tips fit to the contour of the stabilator ends.
However, on the bottom side near the trailing edge some additional work will be required for a perfect fit. Sanding will not be sufficient, it's more that the tips needs to be squeezed a bit together in the last 2 inches towards the trailing edge.
I also haven't drilled the mounting holes yet into the stabilator ribs, so I still have the option wether to finally install the tips or not. The additional weight including J-nuts and fasteners is 2lb and 3oz which is not quite zero and it is a long arm from CG.
What I am wondering is the aerodynamic effect to them, if there is one at all.
So I am looking forward for some opinions of you, the aerodynamic experts out there. Dou you think the tips are for any good in terms of aerodynamic efficiency.
Thanks a lot.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 05-31-2015, 06:02 PM
rgmwa rgmwa is offline
No aerodynamic expert here. I think they look great, doubt whether they will add any speed, and had the same fit issue you found. I eventually decided not to install them because I wasn't comfortable with the not-insignificant extra weight on the all-flying stab. However, there are lots of people happily flying with them, so maybe I was worried about nothing. Wouldn't be the first time, and they do look nice.
rgmwa
RV-12LR 912ULS
120346
Old 06-01-2015, 05:38 PM
Mich48041 Mich48041 is offline
If I calculated correctly, 2.2 pounds added to the stabilator will have the same
affect on aircraft balance as 4.6 pounds in the baggage compartment.
That affect can be mitigated by eating a few more $100 hamburgers.
Joe Gores
RV-12 Flying
Old 06-01-2015, 06:29 PM
Good thinking Joe, but then I might be forced to reduce my fuel load to compensate for the total load increase, and not be able to get home from the last hamburger stop.
rgmwa
RV-12LR 912ULS
120346
Old 06-01-2015, 07:21 PM
How accurate are your scales for the empty weight calculation? Look at the error margin in the original CG calculation and see if this is noise level.
