Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 05-29-2015, 07:07 AM
RV8iator's Avatar
RV8iator RV8iator is offline
Default ADSB or ADSB+
Question for avionocs gurus. I just got my GTN650 software upgraded and have all the latest versions in all avionics.
My question is about the difference between ADSB and ADSB+. I have a Trig TT31 transponder and the way I understand it, the plus part of the ADSB out of the 650 is for Garmin equipment linkd to it but not other brands.
Anybody know if this is correct? My ADSB out passes the test right now and Im wondering if I need to change to the plus setting.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 05-29-2015, 07:13 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
This is from the TT31 installation manual. Emphasis added
"With the Garmin ADS-B protocol selected, the TT31 is compatible with both the Garmin ADSB and Garmin ADSB Plus protocols.
NOTE: GPS sources providing data using the Garmin ADSB protocol will not meet all the FAA requirements contained in FAR 91.227. For installers seeking compliance in the USA, the GPS source must use the Garmin ADS-B Plus protocol."
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 05-29-2015, 07:28 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
What Bill.Peyton said: Use ADS-B+ to be 2020 compliant within US airspace.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 05-29-2015, 12:32 PM
You must use ADSB+, ADSB (no +) was a mistake. Also, your TT31 must have software 3.12 or higher to read the plus output.
Old 05-29-2015, 01:37 PM
Smilin' Jack Smilin' Jack is offline
Hey Jerry,
On the Dynon Skyview which I am sure is similar to yours it was the ADSB+
that finally worked. And a new software 12.2 for the Dynon.
Have you done gone to the FAA test page to see your results.
It is called the US Department of Transportation
Federal Aviation Administration
ADS-B Compliance Monitor
You make a short 1/2 hour flight, send an email to this address with the following information
9-AWA-AFS-300-ADSB-AvionicsCheck@faa.gov with the following information:
•Aircraft N-Number
•ADS-B Manufacturer and Model #
•Position Source Manufacturer and Model #
And you'll receive a full report of your flight in about a day.
any red boxes... you've still got issues to deal with.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
