Old 05-13-2015, 03:06 PM
Walt's Avatar
Walt Walt is offline
Default Quiz - What's wrong with this Gascolator installation?
I stumbled across this during a condition inspection, can you spot the problem with this install? (Ignore the wires, thats not the issue here).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-13-2015, 03:10 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
The letter 'T'
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Timbeck2 Timbeck2 is offline
I've never built an RV.....yet but as a former jet engine mechanic I'd say that is a major risk for chaffing against the firewall.
Old 05-13-2015, 03:11 PM
crabandy crabandy is offline
Teflon Tape!
RV 7 400 hours and counting
19 donation done
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Doesnt that unit feed from the back??? Note arrow directions in image below.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-13-2015, 03:15 PM
Mel's Avatar
Mel Mel is online now
The first things that catch my eye is that the fire sleeve on the inlet side has no clamps. One end has a tywrap, but that might as well not be there unless it's fireproof. None of the fire sleeve ends are "sealed". Teflon tape on the pipe threads.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-13-2015, 03:18 PM
Walt's Avatar
That was quick and Mike wins a beer at Osh!
This picture makes it a little clearer whats going on... the feed is from the back like Mike indicated, this was just acting large pass through heat sink, with no filtering.
The worst part is this was on a very old RV6 with sloshed tanks and this was the only filter except for the carb inlet where I found debris, been overlooked for probably 20+ years
(true teflon tape is also a good find and missing firesleeve clamps)
Old 05-13-2015, 03:20 PM
Mel's Avatar
Sorry I couldn't make out the arrows in the picture.
Mike S's Avatar
Senior Curmudgeon
Thanks Walt, I bought one of those units thinking it was dual input, single output--------was going to use it on a high wing project.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-13-2015, 03:21 PM
Flying EMT's Avatar
Flying EMT Flying EMT is offline
Default You dirty coppa
Copper line on the top. (for a primer?) ....Can work harden
Ben Hubbard
180 hp RV-4
Enstrom F-28C
1979 Decathlon (In recovering mode)
KFOK Long Island, N.Y.
