Old 05-11-2015, 09:26 AM
borvaprops borvaprops is offline
Default component overhaul
Hello everyone Im not sure if this is the best section to post this. Im looking for a good small shop recomendation to get acessories overhauld on different lycoming engines mostly io360 and io540.
Magnetos, fuel injectors, fuel pumps, fuel servo, carburetors.
regards,
Old 05-11-2015, 09:51 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Gabriel, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-11-2015, 09:54 AM
Don at Airflow Don at Airflow is offline
Default Fuel injection overhauls
We are an FAA Repair Station that overhauls Bendix / Precision fuel injection systems and components. We also overhaul Lear/Romec fuel pumps.
As well as our own design experimental fuel injection systems we also overhaul Bendix fuel injection systems for experimental aircraft installations.
If you need additional information or pricing give me a call at 864-576-4512.
Don.
Old 05-11-2015, 02:03 PM
Raymo's Avatar
Raymo Raymo is offline
I used Maxwell Magneto in Florida. Recommended by a friend and long time builder/RV-8 owner. Happy with the service and pricing. About 1 week turn-around, if I recall.
201 Airport Rd
Bunnell, FL 32110
386-437-9700
Ray
Old 05-11-2015, 02:26 PM
az_gila's Avatar
az_gila az_gila is offline
I've used Arizona Aircraftsman in Prescott AZ.
They take care of the well used Embry-Riddle planes and do the accessory overhaul in their own shop. Worth a call to check -
http://www.air-craftsman.com/
There may be a similar outfit near the main Embry-Riddle school in Florida.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-11-2015, 02:29 PM
g zero g zero is offline
Default Overhaul
I also recommend Maxwell Magneto . They are located at my home airport
KFIN
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
