Old 05-09-2015, 11:27 PM
rjbob rjbob is offline
Default Problem With My Plasma II
On a flight from Yakutat, Alaska to Anchorage my engine started to shudder, misfire, and backfire.
After doing all the look-for-place-to-land planning, I did my troubleshooting. The right ignition was the culprit. By running on the left ignition only, the engine ran smoothly.
The right ignition behaves as if the timing is out of whack. Today, I only had time to check to see if the timing lights on both sensors come on at the same time...they do.
Now I have to "hit the books". That said, my initial research in the manual doesn't seem to address this particular problem.
Anyone have experience with this?
Engine...IO-360
Bob
Bob Edison
RV-7 N749ER...(GO NINERS)
ATP CFI-II-ME
Anchorage, Alaska
Let me know if you're RVing to Anchorage!
Old 05-10-2015, 09:58 AM
deek deek is offline
Are you using the mag hole Hall Effect modules? If so, e-mail me longez at sbcglobal dot net
Good you are reading the manual; that will be Klaus' first question...
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 05-10-2015, 03:39 PM
bhester's Avatar
bhester bhester is offline
Default My problem and how I solved it.
I had a problem with my Halls effect sensor, read all about it here, might not be your problem, but it might be:
http://home.newwavecomm.net/bobbyhester/2012Flying.htm
Haven't had a problem with it since!
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 05-10-2015, 03:51 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Good luck getting it fixed if it's the brain box. Do other trouble shooting to make sure it's not a bad connection or bad plugs or coils. If you determine the brain box is bad, be prepared to spend some money.
I had a brain box go bad which was verified by swapping the box with a known good one and putting my bad box in the another plane with an LSE ignition. The problem followed the bad box.
When it was sent into LSE, Klaus said he could not find anything wrong with it. Since he couldn't fix it, I didn't even want it back and I sure was not going to buy another one from him.
I replaced it with an PMAG.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 05-11-2015, 06:56 AM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
I've replaced two Hall modules.
Jerry Esquenazi
RV-8 N84JE
Old 05-11-2015, 08:07 AM
Jerry Esquenazi
RV-8 N84JE
I'll see your two and raise you one
Old 05-11-2015, 09:29 AM
flyingriki's Avatar
flyingriki flyingriki is offline
Send it in anyway. If he says nothing is wrong with it, reinstall and don't be surprised if it works.... I'll let you figure out why...
Do check all plugs. They are cheap and mine failed twice into the Hall Effect Sensor. A buddy replaced it with a quality part that worked fine.
Old 05-11-2015, 02:17 PM
krw5927 krw5927 is offline
Sounds eerily similar to my experience with a PMAG. No problems now with 2x magnetos.
Kurt W.
RV9A
FLYING!!!
Old 05-11-2015, 06:54 PM
Update...
It appears that the problem may have been caused by dirty/oxidized contacts in the Cannon Plug going to the right Hall Effect sensor.
Before doing any work on the the engine this morning, I started it and again noted that the RIGHT ignition was still causing the engine to misfire and backfire. Then...
In order to isolate the problem, I switched the plugs going to the Right & Left sensors. I noted that there seemed to be an oxidized coating on the pins.
Anyway...
I started the engine (knowing that the Left switch controlled the Right ignition and vice versa) and the problem disappeared. The engine was started 6 times and I ran it up every time. At full power, mid throttle and idle everything was normal with normal RPM drops at at all throttle settings. So I think that my problem stemmed from some pins in the plug making contact while others weren't.
I believe that disconnecting and reconnecting the plugs scraped off the oxidation/dirt from the plugs.
I am home now to pick up "stuff" I'll need to remedy the situation. Contact cleaner, silicone (a light coating around the plug to prevent moisture and contamination), and mild thread lock.
I'm about to call Klaus, also.
Rest assured, I will not fly the plane again until I've spoken with Klaus and tested the **** out of the engine.
Thanks for all your help...especially deek!
Bob Edison
Bob Edison
ATP CFI-II-ME
Anchorage, Alaska
Old 05-11-2015, 10:45 PM
RV8Squaz's Avatar
I think next time, I'm gonna fold and install the ring gear pick up. I don't have a good poker face!
Jerry Esquenazi
RV-8 N84JE
