Old 05-05-2015, 04:06 PM
Jetj01 Jetj01 is offline
Default Awesome!!!
Axel, Very nice!!! Love the lines!
Jj
Eagles Nest, TX
Built and FLYING RV-4 Fastback!
SOLD RV-6/RV-8/Rocket
Retired USAF, Current Boeing Driver
Old 05-05-2015, 04:10 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Axel----------lookin good
The fastback just makes the already fantastic lines of the 4 all that much better.
Icing on the cake
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-06-2015, 04:06 PM
sblack sblack is offline
Originally Posted by AX-O View Post
Fuel sender units.
Strobe pack
Thank you!
Are those the belite units? I am planning to use their system. I like the ideanof nothing inside the tank
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 05-06-2015, 06:24 PM
AX-O's Avatar
AX-O AX-O is offline
They are Princeton fuel senders. The inside of the tank has the Van's capacity plates.
http://www.aircraftspruce.com/catalo...fuelprobes.php
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 05-07-2015, 10:38 AM
thank you. Good luck getting the last few things done and flying!!!!
Scott Black
VAF dues 2020
Old 05-07-2015, 11:08 AM
JonJay's Avatar
JonJay JonJay is offline
AC - gotta know, what did she weight out at?
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-08-2015, 09:30 PM
AX-O's Avatar
Well i sent the paper work in to the FAA on last thur. Today my registration is showing an airplane and not a reserved N-number. One week i was prepared for weeks of waiting. Weight and balance tomorrow.
Axel
Old 05-10-2015, 08:50 PM
AX-O's Avatar
Well I tried to get a video of the first engine start done but my devices don't want to play.
That being said. Today I started the engine. Had all the systems working.
A few thing went wrong:
-A couple of fuel fittings were not as tight as they needed to be so they leaked during fuel checks. Got it corrected.
-Operator error. I followed the check-list but when it said "BAT ON" I used the wrong battery switch. I have a way to drop the battery/start contactor. after a few seconds of frustration. I told myself to think and I figure it out. It was a habit that I developed from doing all my ground tests. Instead of wasting battery life, I kept by-passing the contactors.
-The RPM indicated was twice the actual. I chose 1 on the EFIS. I will set it up to 0.5 pulses.
That was it. Now to schedule the DAR.
Axel
Old 05-11-2015, 08:31 PM
AX-O's Avatar
Finally got a quick video up.
http://youtu.be/8XcxhNKSZFA
Axel
Old 05-12-2015, 06:37 AM
krw5927 krw5927 is offline
Set at 1ppr, your engine monitor is expecting 2700 pulses in one minute at full rated rpm. But the reading is twice as high as you're wanting, which means there are 5400 pulses actually occurring in that minute (at 2700 rpm). If you set the engine monitor to 0.5, it will be expecting to see 1350 pulses but you're feeding it 5400, which means the reading will be 4x high.
Set the engine monitor to 2ppr and things should come down where you want them.
Congrats on the start!!!
Kurt W.
RV9A
FLYING!!!
