05-05-2015, 09:10 AM
New RV-10 Door Handle
Hi All,
I am officially releasing my door handle and my company, AV8R Designs.
And I'm finally an official advertiser on VAF.
As they say, necessity breeds invention.
The stock RV-10 Handles are just pretty blah. I wanted something that would look better, not interfere with the functionality of the Plane Around latch, and be easy to install.
In order to get the handle I designed made, I had to have a "batch" made. I put the extras up for sale and they went like hotcakes. So, now I'm offering them up for sale.
This is a 3 piece design, highly polished 6061 Aluminum.
Only requires a quick modification of the door pin. No cutting fiberglass. Installs in about 10 minutes. Great for already flying planes.
The kit includes 2 handles, 2 bezels, 2 buttons (plus a spare), 2 nylon spacers and detailed instructions.
Note: I've discovered that some RV-10 door pins are longer than normal, so I've included a nylon spacer for under the bezel. It can be sanded down thinner if need be. Most will be fine without it.
The Handle retains all the normal functionality in a sleeker more elegant fashion.
$205 shipped in the US (contact me for outside US shipping). Payment via Paypal
Email or PM directly, You can also go to my website:
www.AV8RDESIGNS.com
I have some new products in the works as well. I'm also working on a T-shirt line that I think this crown will love.....
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system!
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
Reason: typos
05-05-2015, 09:19 AM
Senior Curmudgeon
Congratulations!!
John, congrats-----------I know it has been a long time coming.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-05-2015, 09:25 AM
Thanks Mike.... Took a while for it all to come together. Took longer to get a logo done that it did to design the handle... sheesh!!!
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
05-05-2015, 05:43 PM
Congrats John
Congratulations getting the handle out and the new company!
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
05-05-2015, 07:10 PM
great product
We have installed on our 10 and very happy with product and vendor!!
Jack Maljaars
Rv10
N819DJ flying. 350hrs +
Dues 2015 pd
05-05-2015, 08:32 PM
Thanks Jack, you were the first person to get the "official" written out directions. I hope the install was easy. Incidentally, did you need to use the spacer? Just curious. Trying to figure out what % of doors are different.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
05-10-2015, 04:14 PM
I finally got my handles fitted about a week ago.
I had an issue with a gap between the flange and the door. It appears that not all doors fit the same way as the prototype. I was recommended to use plastic washers but couldn't find any the right size. Eventually I found some steel washers and bonded 2 to each flange. With a bit of filling and painting, I came up with an acceptable solution which looks good.
My opinion - nicely made product but need a bit a development.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
05-10-2015, 07:20 PM
Paul,
As you can see from above, the kit now ships with a nylon spacer. It took a while to find out that Vans has an inconsistency in how the door pins fit in the door.
I have extras in stock now and can send you a pair if need be.
Let me know thanks,
John
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
05-11-2015, 07:11 AM
Aah. I didn't realize this was a new thread - thought it was your original
So, it HAS been developed......
Thanks for the offer of the nylon washer but I glued, ground to fit and painted the steel ones so the work is all done.
Paul
2019 Donation Made
06-05-2015, 10:13 AM
Works Great with ACS Locks
Finally got to install my own set of handles!!! And locks on our plane.
Based on what I've seen some others do, I had been planning on using the simple baggage door lockset to secure the door in a locked position.
I had specifically planned the height of the handles so they would clear the locks.
Turned out a little better than I expected.
For anyone wanting to do the same thing. I'll make up some directions.
The basics are: the lock center is exactly 1" from the door pin hole(double check your measurement), Bend the "tab" of the lock to hit the gear rack, also, we fount it works best and is strongest if you make the hole for the lock the actual shape of the lock. IE, flat on two sides, This will prevent the lock from spinning. It's a tight spot to get a wrench in to get very secure.
Locked, with lock hidden:
You can turn the handle just enough to get the key in to lock/unlock
In the full open position
Inside the door, Locked
In the stopped position where you can put the key in from the other side
RV-10 Door Locks in place!!
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
