  #21
Old 04-30-2015, 08:17 AM
Default RV-10 Install
So what are your thoughts about an RV-10 install considering the battery is in the back...sounds like you will still need a contactor in the back with the battery...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 04-30-2015, 11:06 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Technology
There are people who swear by new technology and some who swear at it.
I am of the belief that simpler is better (KISS). Take our latest generation of cars. Lots of electronics and only the dealerships have the secret sauce to fix them.
What I like about my plane is that I can actually work on it and debug most of the systems. Sure some of the electronics (I have Dynon and Garmin) may have to be returned if not working but the fundamentals that keep the plane flying are extremely simple. So if my Dynon and Garmin stop working in flight, I can keep flying. When on the ground I can debug just about any engine/ignition problem. If there is a problem the ignition parts, they are inexpensive and readily available.
Technology improvements are great but they have to bring greater functionality, reliability or value. If they don?t, I don?t believe they are worth the time or money.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 04-30-2015, 11:25 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Good product
Keep in mind this will not be released until it has sufficient time in service with test units. Things are always evolving. Some embrace it some don't.
The PPS will save some install time, although to most it is not a big factor. I know people have mentioned the issue "what if it fails?" We can apply that logic to anything. In reality how many failures have occurred with a master relay and start relay? Not many.
Everybody was concerned about the VPX being the internet popular, "single point of failure." That has not materialized. Conventional breakers are old school but still valid. Too me a panel looks a little strange with all the modern glass then a panel full of old school breakers.
I will say the price of the PPS might be a limiter for many. I was hoping in the $500-$600 range. Especially since doing it with a start relay and master relay will only be about $100.
Lets see how it plays out. I commend them for modernizing and coming up with new solutions.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 04-30-2015, 11:29 AM
rwthompson67's Avatar
rwthompson67 rwthompson67 is offline
I had a battery contactor/solenoid fail on me last year on an IFR flight. I lost all electrical power. Fortunately I was VMC and dropped into a nearby airport with a mechanic on duty. He cannibalized a contactor out of a 182 and I was on my way. These are mechanical parts, they fail. It seems solid state would be an improvement in safety/reliability. No?
Old 04-30-2015, 11:36 AM
Bavafa Bavafa is offline
Originally Posted by kevinh View Post
Yep - my thought as well. Wiring up this section of the firewall was really pretty quick and easy.
Yeap, it sort of remind me of a friend that spends another extra $1000 on his bicycle that is a few grams lighter. I asked him, isn?t cheaper to lose that extra 18 grams then spend so much money on a set of rims to save a few grams. But then again, some people won't mind spending thousands to save a few and since it is their $$$, more power to them.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 04-30-2015, 11:39 AM
YellowJacket RV9 YellowJacket RV9 is offline
While this would be out of my price range, there are certainly plenty of people to whom money is really no object (that seems to apply to many RV builders), and will gladly pay to have the latest and greatest. I don't begrudge them that, and in fact I thank them, because the early adopters are what help the new products get developed, and eventually, be priced within reach for all of us. Most likely, when it's time to replace my relays and solenoids, something like this will be a viable and cost effective solution.
Most new technology isn't cost-effective at first. It's the early adopters who help make it so.
Thanks to all the vendors out there willing to take the risks to bring these things to market.
Chris
Chris Johnson
Old 04-30-2015, 11:42 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Wow, what a concept
Well said Darwin.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-30-2015, 11:46 AM
BillL BillL is offline
Default Hey Chad
You have not talked about additional features. Back in the early '70's VW had this magic "diagnostic" plug that could do engine analysis at service intervals. Mostly it was premature and a failure, but it did have a couple of cool features that worked very well.
The first is compression test. When the engine was spun with the starter, it would measure the amp draw accurately enough that it would give a relative compression reading for each cylinder. The second was a battery discharge test. It would apply a small known resistive load and then record voltage drop and give an assessment in % of battery capacity. Both of these (and more) could be easily integrated into the new module. So - what new cool features can this thing do that, beyond just a replacement for the contractors, would add to a pilots confidence in the health of the airplane?
Bill
RV-7
Lord Kelvin:
Old 04-30-2015, 12:06 PM
TCONROY's Avatar
TCONROY TCONROY is offline
Originally Posted by Mark Dickens View Post
That barrel connector will be a lot of fun to wire up...not
Mark, CPC connectors are extremely easy to wire. All you need is the terminal crimping tool which you can find pretty inexpensively on eBay. I'm sure they will be providing a mating harness with wires so you won't even have to crimp the terminals.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 04-30-2015, 04:17 PM
PaigeHoffart PaigeHoffart is offline
Can someone please explain why it would be a good idea to hook two alternator B-leads to the same terminal?
Or, did someone just mis-label the mockup?
Paige
