Old 04-27-2015, 02:42 PM
ao.frog ao.frog is offline
Default An alternate 180 and 200 HP engine for RV's?
I came across this site today. It looks like they have two engines suitable for RV's: 180 and 200 HP.
108 kg engine weight is pretty good.
It says on the site that max RPM is 3200. I thought that max RPM for the traditional props where 2700? no? In that case, maybe they have another prop in their sleeve..
In any case; it'll be interesting to see how they are doing in the time to come.
It says on their site that FF kit is "under development" for RV-12 and RV-8...
Does anyone know more about these engines? For example how many are flying and for how long?
http://www.ulpower.net/
Looks like they are at S&F with their 200 HP engine...
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 04-27-2015, 04:58 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by ao.frog View Post
Does anyone know more about these engines? .
I had a short flight in a SuperSTOL XL with the 180 HP engine last week, and it performed well. I have also flown the 100 HP model in a Zenith (a couple of years ago) - a very nice engine that I hope does well.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-27-2015, 05:39 PM
DanH's Avatar
DanH DanH is offline
I poked around a bit inside a dismantled 4 cyl model at the show (very interesting!) and flew the same Super STOL as Paul. I think the six has a lot of potential for an RV installation. Verrry smooth...felt and sounded like the old O-300 Continental 6-cylinder. I liked it. Much more later, in Kitplanes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-27-2015, 06:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default UL engine
Wow. That's quite a change and auto gas too.
How it will compare in cost to an equivalent Lyc?
Do I read the specs correctly? 6 cylinder 200 hp engine weighs almost 100 lbs less than the equivalent Lyc 180 hp variant with exhaust.
Does it have a hollow crank version for constant speed?
Is it physically so different as to require a totally different cowl?
What about prop? Can it spin a Hartzel CS prop or will it require a special prop?
Tail Draggers will have even more CG issues to offset 100 lbs off the nose.
Exciting.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-27-2015, 06:29 PM
I have flown a Jabiru 3300, with 120 hp at about the same 3,300 rpm, and it pulled very well. It surprised me how well that high rpm worked.
Dave
Old 04-30-2015, 12:33 AM
Default S&F?
Have anyone been at their booth at S&F?
If so, anything to share?
Thanks.
