Old 04-29-2015, 09:50 AM
cjensen's Avatar
cjensen cjensen is offline
Default The all new Vertical Power Primary Power System (PPS)
News from Astronics Ballard Technology! The Vertical Power Primary Power System was officially launched at Sun N Fun last week, and for those of you that weren't able to be at the show to see it in person, here are a couple of pics and some details.
The front or top side of the new case, this is a 3D printing of the new product from the CAD drawings.
Pretty self explanatory with everything labeled for easy installation and hookups.
The back or bottom of the case...here we have the main buss out lug and a canon plug for data and possible low power (start input and alt field wire will use this plug).
And here is the info board from the show-
I know there will be many questions coming...and I will answer all of them as best I can. ONE THING THOUGH...I AM LEAVING ON VACATION TONIGHT UNTIL MAY 11TH, SO PLEASE KEEP THAT IN MIND. I wanted to get this out there for you all to see that it's real!
Beta testing is slated to begin in July with production expected after that period, which is approximately 3 months. I want about 500 hours of test time on the beta units before it is released.
Price...well, we still don't know exactly where that will be at this time because we still have some minor engineering to iron out (alt field wire hookup is one), but as soon as I know, I will post the info. There are some numbers floating around in the $1200-1800 range for single and dual battery versions respectfully, but we just don't know for sure yet. It will be worth it though, I promise!
Size...Production prototype is 8.6" x 4.7" x 1.5".
More to come!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 04-29-2015, 09:52 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
That barrel connector will be a lot of fun to wire up...not
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 04-29-2015, 10:09 AM
krw5927 krw5927 is offline
Not to mention this appears to be a $1200 solution to a <$200 problem. I was sincerely hoping the price point would be competitive, but wow.
And if the back plate is aluminum, which it appears to be, then I also question the assertion that firewall integrity is maintained.
Kurt W.
RV9A
FLYING!!!
Old 04-29-2015, 10:21 AM
cjensen's Avatar
We will more than likely have a harness available for that connector. They actually aren't all that bad, but for those that want to skip that, we plan to make that available.
Chad Jensen
Old 04-29-2015, 10:27 AM
cjensen's Avatar
In order to make this as reliable as possible, we went with top of the line components...we want you to use this and never have to send it back for repair. Yes it's more expensive...but we expect it to perform at the price point too.
The unit will be completely tested for all firewall conditions including flammability, vibration, and temperature, among a menu of other tests.
This is intended to be an absolutely superior product to what we are replacing and do the same thing the VPX did...completely modernize and simplify this system.
Chad Jensen
Old 04-29-2015, 12:27 PM
Ghost two-six's Avatar
Ghost two-six Ghost two-six is offline
You know what guys - there's a reason why we chose to fly EXPERIMENTAL aircraft - there's something fundamentally WRONG with us ! As my brethren that will not venture away from their Pipers and Cessnas and Mooneys have repeatedly told me. Let's keep that in mind whenever we start to look at something just a little different and new.
Save Money - Outsource Congress !!!
Old 04-29-2015, 01:58 PM
Sig600 Sig600 is offline
How much is your time worth?
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 04-29-2015, 02:14 PM
Walt's Avatar
Walt Walt is offline
If you're building an airplane not much ....
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-29-2015, 02:41 PM
kevinh's Avatar
kevinh kevinh is offline
Yep - my thought as well. Wiring up this section of the firewall was really pretty quick and easy.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 04-29-2015, 02:56 PM
cjensen's Avatar
...and this will be quicker and easier.
BUT, it's not just about time. It's not just about money. It's not just about the solution to a problem. What we are doing is making it better...overall. Modern. Reliable. Safer. Those are the things we are going for here and while price is a big factor when choosing products, we really feel this one will be worth every penny.
Chad Jensen
