Old 04-26-2015, 06:11 PM
pilotdds pilotdds is offline
Default windscreen removal
Well I have decided to replace my windshield before I paint the 116KR. Does anybody have any words of wisdom about the removal process, which I am absolutely dreading?
I have heard a router will help, but I can't find any information from other builders as to how to approach this process.
Any advice will be much appreciated.
Jim rv-10 builder
Old 04-26-2015, 07:04 PM
AaronG AaronG is offline
I replaced my windshield after getting cracks during the initial install. It really wasn't that difficult, though I didn't have the composite fairings installed. Removing them will probably be the hardest part. I used a heat gun to remove the windshield. The glue provided by Van's softens before the composite is damaged if you are careful. I cut out the plexi, leaving an inch past the glue. I then used pliers and the heat gun to remove a few inches at a time. Took a few hours.
Aaron
Old 04-26-2015, 11:43 PM
N15JB N15JB is offline
IIRC Jesse has done this. Search the archives for his description of how to do it.
Jim Berry
RV-10
Old 04-27-2015, 06:23 AM
Jesse's Avatar
Jesse Jesse is offline
I have done it. The windshield was broken due to being hit by a crashing Columbia. I used a rubber mallet and broke off one piece at a time. It popped loose fairly easily from the glue in small sections (6" or so each). It was not installed with Weld-On from Van's. After that we used a die grinder with a coarse grit sanding disk to remove the glue back to the original fiberglass lip.
Jesse Saint
Old 04-27-2015, 10:54 AM
greghale greghale is offline
Default windshield removal
I had to replace mine after I got a scratch on the inside. This link shows how I did it.
http://www.nwacaptain.com/windshield.html
Actually the repair was not as bad as I expected.
Greg...
Old 04-27-2015, 03:37 PM
thanks you guys-Greg that is an excellent guide.
