Old 04-20-2015, 03:07 PM
n468ac's Avatar
n468ac n468ac is offline
Lightbulb Initial review of the low cost AP510 APRS Tracker
INITIAL REVIEW of the low cost AP510 APRS Tracker with GPS/Bluetooth/Thermometer/TF Card Support/APRSdroid.
This is a small portable aprs tracker. So far I like it, but will report back over the summer as I make some long distance travels.
PROs
self powered
easy to program
smart + manual beaconing
records data to flash card
portable
active Yahoo Group for english support
metal case (except top where GPS chip is installed)
use any mini USB cable for charging
CONs
battery life unknown (some report 24 hours with two min beacons)
bluetooth limited to android
1 watt output
Thermometer built into unit
special programing cable need (comes with unit)
Found: (also on EBAY)
http://www.sainsonic.com/ap510-aprs-...aprsdroid.html
Flight Tracking:
AP510, using old GPS suction cup mount and 3M mounting tape:
My configuration:
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 04-20-2015, 03:31 PM
Thanks for the initial test review. I've been curious how these perform. I already have a solution for my airplane but this is nice that is a portable option - great for when flying with someone else or for those in certified airplanes.
I'll watch for any updates you find share-worthy!
Old 12-20-2015, 10:33 AM
n468ac's Avatar
Thumbs up UPDATE - 12-20-2015
I've found this little tracker to work much better then I expected! I've got my configured to transmit every 120 seconds, I'm not using the "smart beaconing" functions. With it setup for a 120 second transmission I found the battery to last 16 hours. Thats enough time for my flights.
Here is a screen shot from yesterdays flight C09 to CMX at 3500 feet. The return trip CMX to C09 at 8500 feet. You can see i got my packets received all along the way from this little 1 watt tracker.
RV-6A - N468AC
N468AC Web Site
