Old 04-20-2015, 06:00 AM
samiamPA samiamPA is offline
Default Older kit - corrosion?
Hello VAF!
I recently bought a tail kit that a builder had purchased way back in 2002, and essentially never started. Most of the metal was still covered in the blue plastic, and when removed looked great. But there were 3 ribs for the VS that were previously devinyled by him. These looked fairly dull, and I am concerned about corrosion. See below, this is the worst example:
https://drive.google.com/open?id=0B0...Uw4&authuser=0
My plan was going to be:
-Use a maroon scotch brite pad to buff out these darker spots, then clean and prime to prevent further corrosion.
Does this sound reasonable?
Old 04-20-2015, 06:38 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Originally Posted by samiamPA View Post
Hello VAF!
Yes...that doesn't look too bad to me.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 04-20-2015, 06:49 AM
jaradtke's Avatar
jaradtke jaradtke is offline
Most of the formed parts that come from the factory have that dule appearance. Ribs don't typically have vinyl wrap on them.
Jeff Radtke
Lutz, FL
RV-7A - SOLD
RV-7A - New Build
Tail Feathers - Complete
ER Wings - Complete
Fuselage - Complete
Finish - Started
Old 04-20-2015, 07:25 AM
BillL BillL is offline
Yep, looks normal to me. Still building a kit from 2002ish. Prime or not - your choice. Actually, if I was to do again and wanted corrosion protection. Alodine tank dip is pretty easy, fast for protection.
Bill
RV-7
Lord Kelvin:
Old 04-20-2015, 07:29 AM
wirejock's Avatar
wirejock wirejock is offline
Default Welcome
Welcome Sam.
Your plan is good. I did the same. My empennage was several years old too.
Order the Horizontal Stab Service Bulletin. You might as well install it now.
Check out my blog, "empennage" page. Scroll to the bottom. I tried to document the assembly of the HS when I rebuilt it.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-20-2015, 08:14 AM
Arie's Avatar
Arie Arie is offline
I dont see any corrosion on that part. Corrosion on aluminum looks normally like a white powder residue on the surface. Just scuff it with a scotchbrite pad and prime.
Regards
Arie
Old 04-20-2015, 02:00 PM
Thanks to everyone for letting me tap into your collective experience, and dealing with my newbie questions!
Regards
Arie
This is what I thought--I wasn't sure about the brownish discoloration. Just trying to be as safe as possible though and learn from those with experience.
Old 04-20-2015, 10:19 PM
terrye terrye is offline
Default Not Corrosion
Most parts with formed flanges (ribs, bulkheads) are formed in the soft or 'O' temper condition. Then they are heat treated to the final such as 2024-T3. Your rib looks like normal heat treat coloring. If you are not going to primer it, leave it alone. The alclad surface isn't very thick and if you go heavy on the scotchbrite, you can reduced the alclad thickness and thus the corrosion resistance.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
