Old 04-11-2015, 05:32 AM
mavmitchell mavmitchell is offline
Default Trig Transponder Altitude data from G3X
Does anyone know if there is any way to get serial altitude data from G3X for Trigg transponder. It uses the normal Icarus etc..
Old 04-11-2015, 05:41 AM
Brantel's Avatar
Brantel Brantel is offline
The normal link the G3X uses to talk to the Garmin xponders is dedicated and a hardcoded proprietary format. Not sure what that format is without sniffing the port and reverse engineering it.
I doubt it would work but you can ask G3Xpert to be sure.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-11-2015, 05:59 AM
Walt's Avatar
Walt Walt is offline
And because the 23ES costs less than the Trig, it just doesn't make much sense to run a trig with the G3X.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-11-2015, 08:27 AM
Not approved for use here in oz..
Old 04-11-2015, 09:18 AM
Walt's Avatar
The 23ES is a TSO'd unit, no different then the trig in that regard
Old 04-11-2015, 07:20 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I am using the King KT74, which is basically the TT31 trig manufactured for King. The install manual is the same as the TT31. The KT74/TT31 will not recognize the Garmin G3X output format. I tried using various settings to no avail. I ended up using the encoder output of the Dynon D6 I use as a backup instrument. This works fine, and coupled with the 403W ADS-B+ output passes all the ADS-B parameters.
I would really like to use the air data output from the G3X, but I see no way with the Garmin proprietary format.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
