Old 04-06-2015, 09:09 AM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Default DAR inspection
Time to start filing FAA paperwork for registration and inspection of my RV8 and I have a question about DAR's.
FAA states the DAR may be located in my geographical area. Does that mean the DAR has to operate with the FSDO in my FAA designated region or can they come from anywhere in the nation?
Only one DAR in the Richmond, VA FSDO area. Four are listed in neighboring NC but that's a different FSDO office.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Old 04-06-2015, 09:26 AM
Vern's Avatar
Vern Vern is online now
Default Geographic Expansion for DARs
Normally a DAR-T (FSDO Dar) can only operate within his FSDO area. However, a "geographic expansion" allows a DAR to operate in another area and is a coordination paperwork between 2 FSDOs.
Answer then is to contact those DARs and see if one is willing to request expansion.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 04-06-2015, 09:55 AM
Carlos151's Avatar
Thanks Vern.
Just wanted to have some options.
Karl Richcreek
RV-8
TN26
Old 04-06-2015, 11:02 AM
jrs14855 jrs14855 is offline
Default DAR's
In many cases the DAR answers to the MIDO office, not the FSDO.
Old 04-06-2015, 11:04 AM
Don's Avatar
Don Don is offline
Karl,
I think there's a DAR in Maryland who works in this area that's supposed to be reasonable to deal with. You might check with Dwayne Goss, the airport manager at New Kent for contact info and details of his inspection. It's been a few years but I believe he used that DAR when he applied for his airworthiness certificate on his 8 and was pleased.
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Old 04-06-2015, 11:05 AM
Mel's Avatar
Mel Mel is offline
Many DARs are allowed to do inspections outside their area. I personally go all over, as long as the applicant pays travel expenses.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-06-2015, 02:27 PM
Super Moderator
Default Same as Mel
Getting a geographical extension to inspect a project is really no big deal for DAR's, and it makes sense to have someone who understands your particular aircraft as opposed to just being the local DAR. It really can mean the difference between a fun first flight and a not-so-fun first flight.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 04-06-2015, 08:32 PM
b432291 b432291 is offline
Just be aware that once you have engaged a DAR, you cannot really change that DAR. You cannot "shop" DAR's once you start working with a DAR.
Old 04-08-2015, 09:55 AM
Carlos151's Avatar
Thanks for all the info. Decisions, decisions.....
Karl Richcreek
RV-8
TN26
Old 04-08-2015, 11:26 AM
RV7A Flyer's Avatar
Why not? You mean once I make the first phone call or email, I'm stuck with whomever I first contact?
Don't think so...until they're out there actually inspecting the plane and filling out the paperwork, I'd say you can change your mind and get another DAR at any point if you don't care for the first one's approach/attitude/availability/whatever.
