04-04-2015, 10:53 PM
Bill, that works for me, if it was an exhaust valve sticking...but the sticky one appears to be an intake.
Does low dynamic compression result in a long combustion time? Looks like coffee with Mr. Taylor in the AM
Dan Horton
RV-8 SS
Barrett IO-390
04-05-2015, 06:54 AM
Quite a mystery, #2 seems lean (or less rich) to me compared with the other cylinders - perhaps intermittently.
Look for the obvious first - you mentioned replacing fuel lines - check you are not sucking air somewhere.
Check the carby mounting bolts, check inlet tubes, clamps and flange gaskets. Check the carby's finger strainer and fuel flow.
Doug Gray
RV-6 completed, flying since July 2010
04-05-2015, 08:23 AM
Bill, your supposition about partial sticking at the beginning of the event (yeah, I know, maybe) resulting in increased EGT would work for an intake. There is plenty of data linking decreased compression to increased EGT. Apparently has nothing to do with combustion time, but rather work vs enthalpy.
Example snip borrowed from an engineering school paper:
http://rescomp.stanford.edu/~efroeh/...erformance.pdf
An intake that started sticking just off its seat would lower dynamic compression, and the EGT indication would shoot up. The valve itself would heat very quickly with limited or no heat transfer to the seat. Stem diameter would increase, stick the valve at a point further open, and EGT would tank with no combustion.
Dan Horton
RV-8 SS
Barrett IO-390
04-05-2015, 10:10 AM
Great in depth analysis
I read all of Dan Horton's post with great interest.
Only one thing is bugging me about the whole intake valve sticking.
I cannot refute any of the details or come up with a more likely cause than what Dan has described.
Generally speaking though, exhaust valves are almost exclusively the only valves sticking in aircraft engines.
Rarely is it an intake valve and then only due to improper machining and assembly of cylinder head components.
You'll know soon enough when you remove the rocker valve cover and check you valves.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
04-05-2015, 11:17 AM
Senior Curmudgeon
I had the valve seat come out of the head on an intake valve in my Franklin engine----------wonder if the Lyc is subject to the same issue??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
04-05-2015, 11:34 AM
All my valve troubles were with a Franklin on a Stinson 108
The description of the Op's engine troubles exactly matches my own experience.
But as Dan pointed out a graph analysis of EM data always beats a pilot description.
Mike,
Having an intake valve seat come out is probably more common on a Franklin since there is almost no one left who knows anything about properly assembling a Franklin cylinder. In any case, it is precisely the cause if improper cylinder assembly and could happen in either a Franklin or a Lycoming.
Ernst Freitag
04-05-2015, 11:48 AM
Originally Posted by N427EF
Generally speaking though, exhaust valves are almost exclusively the only valves sticking in aircraft engines. Rarely is it an intake valve and then only due to improper machining and assembly of cylinder head components.
Just for fun, I typed "stuck intake valve" into the word string search block on the NTSB site. Only got two hits, both interesting. CEN12LA384 was a 40 hour airplane, and NYC99LA173 was a freshly "repaired" valve stick.
Repeating the search with "stuck exhaust valve" netted 32 returns.
I guess we could say a stuck exhaust is 16 times more likely, but a stuck intake cannot be discounted.
Review NYC99LA173
Dan Horton
RV-8 SS
Barrett IO-390
04-05-2015, 11:49 AM
I'm still trying to educate myself on the reading the graphs, here's a previous flight before sending the carb in:
https://www.savvyanalysis.com/flight...f-185d49cfb305
Am I seeing LOP at about 1:10 and then ROP about 2:10?
RV 7 400 hours and counting
19 donation done
04-05-2015, 11:55 AM
"Review NYC99LA173 "
So the mechanic unstuck the valve but did not fix why it stuck in the first place, When it stuck again later it stuck closed and the rocker arm ended up being the weak link?
19 donation done
04-05-2015, 12:04 PM
I am a little worried that it was improper machining and or assembly, I was the 3rd owner (far as I know) of the engine after it had been rebuilt.
What is the possibility of my operation close to peak EGT causing the sticking valve? I was always less than 65% power and 380 CHT's, but what about 91 octane and 32 degrees of timing in the mix?
19 donation done
