04-01-2015, 05:21 PM
Senior Curmudgeon
John, I seem to recall that the factory has previously mentioned that the baggage bulkhead is a structural item.
Although I think your splitting it, and hinging the one half is a great way to access the tailcone stuff------------did you run this past the Vans folks???
From the photo, it does not appear that there are any screw holes for the drop down half to be attached to the center post.
Looking good --------- I really like the interior side panels.
Keep shortening that punch list
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
04-01-2015, 06:09 PM
Hey Mike,
The screw holes are there... just can't see them.. We didn't run it by Van's however, what you can't see is that we built a very strong structural frame around the entire opening for that door. I'd say it's stronger than before. We ended up with 2 baggage bulkheads so we were able to make the door oversized to overlap the hole, and it's held closed by 1/4 turn fasteners. I think it's rock solid.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system!
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
04-01-2015, 06:33 PM
John, loving your build. Great job thus far!
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
04-01-2015, 09:01 PM
here's a better look at the access panel
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
04-24-2015, 12:19 PM
No pictures, I'm afraid, but a red-letter day anyway.
Just started my engine for the first time. Came from Aerosport and has been sitting inhibited for 3 years. Standard Slick mags with retard breaker and SlickStart (thanks for nothing Emagair). Dynon Skyview EMS.
Started 3rd blade and ran BEAUTIFULLY. No leaks, all the EMS probes worked as advertised. RPM indication rock steady with a pick off from the P-lead and a 30k resistor. Temperatures came up nicely. Prop control worked after a couple of cycles. In fact, it could not have gone better.
I'm a VERY happy man
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
05-28-2015, 12:37 AM
This update doesn't contain anything new that hasn't been done almost 800 times or so... but, might as well post.
We finally put in the Windscreen, and built the fairing. Went pretty well. Good thing I researched it here. Would never have thought to dye the filer and epoxy black until it was too late....
We also fitted the wings. So, that was kind of big deal. Actually went surprisingly easy. The plane got to get out of the garage and make Uturn back in.
Amazing that these wings left the factory in 2005 and the fuse in 2007, and they went together like butter. A lot to be said for Vans engineering and production.
Made and riveted in an extra bracket for the the windscreen. It disappeared under the fairing once it was all done.
Big thanks to the crew we had come out and help with the wings...
We figured out, between this crew we are responsible for 11 planes either built and flying or in progress... With Al and Shayne being the most repeat offenders...
Thanks to Al Smith (RV-6, Zeinith 650, RV-12, and currently a Zenith 750), Earl Starkman (25,000hr commercial pilot), Frank Klimek (Cub Replica and currently Sonex), Rick "Wingman" Wantz, Sonex), and of course, my father-in-law, Shayne (Sonex Waiex, Zenith 650, Zenith 601 and now the RV-10)
Only some minor trimming has to be done on the flaps..
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
05-28-2015, 04:36 AM
nice pictures john. it is very motivating to see all those pictures, and it's even cooler to see all the people with experience who helped on the project. hope to see the finished product soon!
05-29-2015, 09:58 AM
Great Pics
I love to see this, significant completion of difficult parts of the build and then to find out it really isnt that bad. Thanks
Wish i had a couple of build buddies like that,,,,, can you send a few up here to canada? Alberta?
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
08-04-2015, 02:06 PM
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
08-04-2015, 10:25 PM
Super Moderator
Looks Great
That is looking great John. Can't wait to come to San Diego sometime and check it out.
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1280 Hours)
RV-12 N321UT (Sold)
