03-22-2015, 03:43 PM
SkyView not showing pitch trim position
I'm running SkyView 12 installed from Van's site. I have a pitch trim position indicator in the lower right corner of the EMS display but it's blank - no indication of trim position.
The trim motor operates correctly and I've checked the pins on both sides of the connector on the trim motor and they are correct. I've also checked continuity from the trim motor connector pin 3 (PTRIM SERVO POSITION) to the Control Module (WH-00046 pin 4). After that I get a bit lost in the schematics but I think the rest is purely between the Control Module, EMS Module and the D1000T.
I do not have an Autopilot Knob Module if that's relevant.
I don't see any setup that would affect this.
Am I missing something? What else can I check to shoot the problem?
Tom
Port Orange, Fl
EAA #51411
03-22-2015, 04:00 PM
I had a similar problem. Trim operated correctly but I had no trim position indicator on the screen. Mine turned out to be a bad crimp on the white/green signal wire in the tail cone. Replaced the connector and it worked.
rgmwa
RV-12LR 912ULS
120346
03-22-2015, 04:12 PM
That's what I thought it might have been but I had good continuity from the tail cone all the way to the Control Module. The motor side of the connector looks good.
Tom
Port Orange, Fl
EAA #51411
03-22-2015, 04:18 PM
I had the same problem that
My solution was to go into the setup menu, then hardware calibration, pitch trim. When I did the calibration procedure the trim position indicator magically appeared. I had to look through the setup menu several times to finally locate this cal. All this is from memory so the exact procedure and nomenclature might not be 100% correct. I'll go check my Skyview later tonight or tomorrow morning and report back.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @305
Dues paid 2020
03-22-2015, 04:50 PM
Thanks, Doug. I tried to go that route earlier. You were real close, it's in Hardware Config > ADAHRS Config > Trim Motor Config. The problem is that choice is dim (not selectable) . It says "Trim Motor Config (No SV-AP-PANEL)". Hard to believe we'd require that panel just to get a trim position indicator but, I suppose, possible.
Tom
Port Orange, Fl
EAA #51411
03-22-2015, 05:13 PM
try this
Hardware calibration, ems calibration, elev calibration. That's how I got mine to work, sitting in the plane now looking at it. I set my takeoff trim arbitrarily by a time count of halfway between stops. Probably not the correct TO trim but it's someplace to start. I do have the latest version firmware from Van's (12.1?) . Hope it helps.
N412DR
Kit 120797
HOBBS @305
Dues paid 2020
03-22-2015, 05:33 PM
Hi Tom, Doug is right; the 'Wizard' is listed as 'Elev calibration', not Trim. I did mine 2 days ago & was about to give up when I found it after 15 mins of button pushing! Cheers, DEAN...
You nailed it Doug, thanks. I must have been through those calibration settings a dozen time and never saw that setting in the EMS section.
Thanks for taking the time to find it.
Tom
Port Orange, Fl
EAA #51411
03-22-2015, 05:56 PM
Glad to help! Even if you started your build after mine and have nearly caught and passed me  . My -12 is all ready to fly but it is in my shop,,,,,, at home. Now I'll have to build a trailer to get to the airport. And I need transition training, and I travel to work in nuclear plants all over the US and abroad. Just got back today from 3 weeks in Belgium, go back on Sunday for 2 more. You will probably fly before I do.Best of luck, sounds like you're close to first flight and keep us all posted.
DBR
N412DR
Kit 120797
HOBBS @305
Dues paid 2020
03-22-2015, 06:01 PM
Getting closer but mine is still in my garage. Planning to move it to the hanger in a couple of weeks - guessing a month or so to inspection. I still have my "transition training" to go as well but mine might be a bit more extensive - haven't been PIC in 30 years  . Hopefully it'll be like getting back on a bike
Tom
Port Orange, Fl
EAA #51411
