Old 03-20-2015, 10:30 AM
rfchisholm rfchisholm is offline
Default Painting before I'm finished ... ?
I believe this is a 'no-brainer', but I figured I'd float my question here just to see if there is something I have not considered ... or over-looked.
Later this summer I have an opportunity to paint my RV-12 before it is finished. My finishing kit arrives next month, so I will have everything but avionics and power-plant to complete my E-LSA.
I have a friend who wishes to set up a temporary paint-booth in my hangar so he can bring in a professional painter to do some painting on several planes he owns. My friend runs a business out of his hangar, so he is not able to do the painting in his own hangar-space. In return for the use of my hangar space I'm hoping to barter the services of the painter and the booth while they are set-up in my space.
There are many things in my favor here .... most obviously cost savings and location; I don't have to move my plane to get it painted.
So, here are my questions ...
Is there any down-side to painting my aircraft before it is completed?
For those RV-12 builders reading this ... after my finishing kit is delivered, will I have all the external parts that would be painted?
Thank you in advance for those offering up feedback!
Ronald F. Chisholm
RV-12; N439CH - Flying!
RV grinnin'!
2020 dues paid!
Old 03-20-2015, 11:14 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
There are downsides, but also upsides. Whichever you choose, I am sure you will make it work for you...
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
Old 03-20-2015, 11:34 AM
jetjok's Avatar
jetjok jetjok is offline
Default This Seems Like.....
A no brainer! Even if you are not ready with all the fairings and bits, it would be a great trade! Having a pro to shoot the paint, lay out and paint all the trim details would be a great head start.
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
Old 03-20-2015, 01:15 PM
lr172 lr172 is offline
I expect my 6A to enter Phase I early this summer. I have already painted my fuse (bottom half of two-tone paint job), wings, emp and cowl. It is certainly more convenient to paint in pieces and You end up with better paint coverage of the areas un-exposed once assembled.
Prep is another bonus. I didn't want to use alodine (didn't want chemicals in garage) therefore needed mechanical prep (i.e. sanding). The primer needs to go on within 2 hours of sanding, so smaller parts helps a lot.
Good luck,
Larry
Old 03-20-2015, 01:48 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Yes do it!
I would do it in a minute! I choose to not paint until after I was done figured a few months, ended up being seven years before I got it painted. If I was doing it again I be painting before it was finished.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 03-20-2015, 01:50 PM
bret's Avatar
bret bret is offline
are you going to paint it or have it done? I am painting mine as I go, I could not imagine trying to reach up and fight gravity sanding and preping all the bottom surfaces, it was a lot of work just sanding right side up.
Old 03-20-2015, 02:14 PM
larrynew's Avatar
larrynew larrynew is offline
I painted as I built. The paint shows some wear and tear but one of the big reasons I painted early was to build enthusiasm. It was much easier to justify the time and $ to the spouse and family with something that looked like a pretty airplane in the garage instead of a bunch of metal stuff. I was surprised at how dramatically attitudes changed after most of it was painted. Tacit approval became enthusiastic cheerleader.
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying Phase 1
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 03-20-2015, 02:54 PM
eddieseve eddieseve is offline
I painted before flying and have no regrets, also you need to consider its a well established kit so I don't understand the benefits of waiting till after phase 1 is complete, what are people expecting to find wrong or needing rectification?
I say go for it.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 03-20-2015, 03:37 PM
This was a huge benefit for me. When I painted the fuse, I pulled the engine (it was before I did anything firewall fwd) and flipped the fuse upside down to paint. This avoided doing anything on my back. I couldn't imagine trying to lay paint while rolling around on a creeper, let alone the hassle of sanding on my back.
Larry
Old 03-20-2015, 05:12 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Read this thread for a detailed example.
http://www.vansairforce.com/communit...ad.php?t=67760
Really glad I painted before flying, no issues.
