Jason,
There are 3 kits to choose from depending on what you want. The full kit for the 7A contains 52 fasteners for the cowl plus we include 2 wing head fasteners for the oil access door. The firewall only kit contains 30 fasteners and the side only kit contains 24. Recommended spacing is 3 ? 4 inches. Two tools are required for installation. The 4P3 C-lock pliers (similar to cleko pliers) depress the stud assembly so that it can be installed in the grommet. The T26 snap ring tool installs the retaining ring on the back side of the grommet. Let me know if you need more info.
Best regards,
Jeremy
MilSpec Products
