03-11-2015, 08:17 PM
The gap in the hinge is per plans. But from this second picture, it looks like installation of the air/ oil seperator interferes with the normal access to insert the pins from inside the cowl and the solution was to insert the pins from outside the cowl. No real harm except the gap from cowl to top skin was widened to permit pin insertion from outside and thus the 3/4 inch gap. Appearance issue and not a danger that I see. Maybe others may have another view on this. You do need some way of keeping the pins from backing out. Maybe someone here can post a picture of the way to make a pin retainer.
03-11-2015, 09:24 PM
Thanks for looking. I don't think there is much likelihood of the pins coming out. They haven't moved in the 26 hours I have put on the plane. Removing and installing them requires a pair of pliers.
Thanks again for all the suggestions,
Hank
Hank Cohn
Alpharetta, GA KLZU
N515SK
RV-6
03-11-2015, 10:04 PM
Here is the best picture I could come up with explaining the issue. The hinge on the cowl should be one piece with the eyelets cut out. This adds strength to that 3.5 inch gap and it will not pucker during flight. Some builders use two hinge pieces but this is not correct and the gap is not reinforced. You can probably reinforce this after the fact by adding some sort of stiffener in the gap and either fiber glassing it in or rivet it. It looks like your cowl is painted, so riveting might not be a preferred option.
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
03-12-2015, 06:05 AM
If mine puckers 3/4", the cowl wont be the only thing "puckering!"
03-12-2015, 07:19 AM
Thanks for the education and your ideas. I really appreciate the time and effort it takes to create and convey a descriptive and prescriptive post. I'll take a look at the cowl and see what options exist.
Thank you again,
Hank
Hank Cohn
Alpharetta, GA KLZU
N515SK
RV-6
03-12-2015, 08:00 AM
Cowl pucker
My pins are inserted from the oil door. The top cowl has the three inch gap, but it has a 4 inch layer of fiber glass stiffener that keeps it from puckering. I would just add a 1/4 inch of glass and it will reduce the pucker. My pins did work out but I fixed that. The short pin came out once and you couldn't tell it in flight.
T82 Fredericksburg,Tx.
Don't make easy hard!
Master Pilot Award
RV6A owner N6711
L19 sold
ATP/FE/CFI 10 Type Ratings.
03-12-2015, 09:41 AM
Hank,
I think the problem may be helped by adding enough hinge, so the gap is shortened. My hinge gap between the two sides is only three hinge loops and I don't have any problem with getting both wires in. When flying, the rise in the cowling is barely noticeable.
Jim
03-12-2015, 10:15 AM
pucker
I have the continuous hinge as noted in post 13 on my RV8 and have no pucker issues.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
03-12-2015, 05:34 PM
bend the pin handles so they interlock if they tend to slide
you have probably already done this. I bent the pin handles so they interlock if they tend so slide out. I have no additional pin locking method, works great.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
03-12-2015, 07:40 PM
Mine does too!
Timely topic. I too noticed that my cowl 'puckers' in the same location. Two piece piano hinges and standard baffles. I usually don't see it since my Stratus blocks my view in that area. Mine is more like a 1/4". My cowl does not have the piano hinge in that section so that appears cause some flex in that area, causing the issue.
Bud K
N682TT RV-7
Legal Eagle - Flying
FFR Roadster (sold)
