Old 03-10-2015, 04:35 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Sig600 View Post
The reporter says the airplane sustained "minor damage."
That'll buff out, right?
Glad they're ok. I'd be curious to hear how they got out.
We had lunch with Mike, the builder and pilot, today and chatted with his wife afterwards - both in good spirits, and Mike did a great job of flying to keep them alive. He was in a spot over the mountains with very few options except to get to the flat desert near the airfield, and when he knew he couldn't make the runway, he flew the airplane as far into the forced landing as he could. Lots of sagebrush and soft sand contributed to the flip - it was probably unavoidabe given a nosedragger and the location.
The cockpit is full of dirt, but the rollbar saved them. The fire department got them out by lifting one wing far enough to get them out the broken canopy. Like most A-model fips I have seen pictures of, the cabin was very intact and did a great job of protecting the occupants.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-11-2015, 05:14 AM
pierre smith's Avatar
Default Great
Good news, indeed, Paul....thanks.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-11-2015, 09:19 AM
Chuck Hagerty Chuck Hagerty is offline
Default Quick question
Missed the initial report of this and haven't seen any pictures yet...was this a tip up or a slider?
Good news that both are OK.
Chuck Hagerty
Lynchburg, VA
RV-7A N954CH
First flight 1-29-13
Phase I complete 5-25-13
INVERTED: Looking Back on Walking Away
Old 03-11-2015, 10:16 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Looks like a slider
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-11-2015, 10:17 AM
Ironflight's Avatar
It was a slider.
Paul F. Dye
Old 03-11-2015, 11:16 AM
BillL BillL is offline
Default How does clearance compare . . .
Really glad to know they walked away in good shape . . .
This brings up what the clearance difference might be etween the tip up and slider? I am sorta hesitant to ask this question, but with the same head room seating position for the two, do the two roll bar locations give the same head to ground clearance ?
The tip-up has the line drawn from the nose to the bar, and the slider is between the bar and the VS or aft fuse, if the VS is not included or damaged.
I am assuming each would have equal stretch due to belts, clothes etc.
Honestly, it "looks" like the slider offers greater head to runway clearance. But does anyone know the numbers?
Bill
RV-7
Lord Kelvin:
Old 03-11-2015, 11:24 AM
RVDan RVDan is offline
Glad to hear they were OK. Off airport with soft/variable terrain is almost impossible to stay upright on when we have such small tires.
For fact finding only- The nose gear leg looked like it bent at the mount and at the nosewheel with the rest being relatively straight. Did this aircraft have the antisplat nose job?
I doubt the outcome would vary given the terrain, but it is a test case for how the gear bends if it was installed.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 03-11-2015, 12:27 PM
JDanno JDanno is offline
Looks like the prop wasn't even scratched! Really glad that the outcome was favorable.
Old 03-11-2015, 04:33 PM
sailvi767 sailvi767 is offline
It's great that this turned out well. With the condition of the aircraft it looks like determining the cause of the failure should be easy. Any updates on that aspect of the accident. The why always concerns me so I can hopefully avoid the same issue.
George
Old 03-11-2015, 05:46 PM
DaveO DaveO is offline
I do not know the accident fatalities or injuries between the slider and the tip-up.
I turned my 7A upside down and I believe the roll bar saved me. Only scratch I got was one getting out of the God broken canopy.
I had the antisplat on mine too. Cannot say it did not help, but it turned over anyway.
Sorry to see that happen to anyone.
Dave
