03-09-2015, 11:07 PM
Wheel Balancing
I'm doing my annual and decided to balance the tires. I got the HF motorcycle wheel balancer with a set of weights using double sided tape to fix them. The main wheels went fine, but how do you guys who are doing this balance the nose Wheel? There doesn't seem to be enough surface to work with to attach the weights. Are you guys using the clip type? If you are where are you getting them?
03-10-2015, 06:22 AM
As I recall - -
I taped them in place to be sure I have them where I wanted them. I then GLUED them in place. 5 Minute epoxy if I recall from 5 - 6 years ago.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2020 )
03-10-2015, 06:50 AM
Wheel Balancing
I once had fits trying to balance relatively new, good quality name brand tires. I fly mostly off of grass and knew I had not flat spotted the tires in any way. I spoke to the tire manufacturer at Oshkosh and they suspected that I had let the tires sit on the airplane for a while in one spot and they (the tires) were slightly deformed.....and recommended I fly a few times before trying to rebalance. This advice was proven correct. If you find yourself having to add lots of weight, you might need to go out and fly / land a few times and check again. Most mechanics I've seen use RTV to glue the weights on the wheels. Balancing the nose wheel helps reduce / eliminate "shimmy" on free castoring nose gears so don't give up.
03-10-2015, 07:00 AM
Which balancer did you use? I only saw two HF balancers and they were static balancers. I'm surprised they work well with our small diameter tires.
Tom
Port Orange, Fl
EAA #51411
03-10-2015, 08:29 AM
Static balancing on light aircraft wheels/tires is a common practice and works quite well.
It may be because of the small diameter (compared to car tires) has a lower moment of inertia at a similar speed?
We use the H.F. motorcycle wheel balancer in our shop.
To balance the nose wheel on the RV-12, we stick the weights to the wheel inside of the pass through holes.
Scott McDaniels
Hubbard, Oregon
03-10-2015, 08:51 AM
These are the ones I use. They are a .25 oz each and are small enough to peel and stick just about anywhere. They can be stacked on each other to.
http://www.amazon.com/Motion-Pro-Sil...l+Wheel+Weight
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
03-10-2015, 11:36 AM
Thanks. I tried putting them inside the holes, but as Murphy would have it the solid structure is exactly where I want to put them. The RTV idea sounds interesting. The surface of the metal doesn't seem as "adhesive friendly" as the main wheels no matter how much degreasing I do.
03-10-2015, 11:54 AM
Does the HF balancer do anything that having the wheel on the axle without the nut on would do? I don't get either wheel to move when I do this and I doubt that they are that good?
John Furey, RV7. Ohio
Life's Short...Fly Often!
03-10-2015, 12:48 PM
Yes.
The rotating mechanism of a good static balancer is ultra low friction.
The friction of conventional roller bearings with thick grease in them, (particularly the style on RV-12 wheels that have integral rubber seals) is much higher. You probably wouldn't detect even a badly out of balance wheel condition with the wheel installed.
Scott McDaniels
Hubbard, Oregon
03-10-2015, 12:49 PM
No big deal... just split the weight between the two holes to either side of that point.
Scott McDaniels
Hubbard, Oregon
