Any combination of the switches can be on at the same time, but they will have the following order of precedence:
If the pulse switch is on the light will pulse regardless of the state of the landing and taxi switches.
If the landing switch is on (but pulse switch is off), the light will be in landing mode regardless of the state of the taxi switch.
If the taxi switch is on and the other two are off, only three LEDs will come on for the taxi mode.
Originally Posted by kblack
Dean:
Thanks for the quick reply. Any chance we can get a diagram? I still can't figure out just what I need to plan.
I am assuming 3 switches that are not interlocked in any way will work:
- Landing
- Taxi
- Pulse
If so, do the Landing and/or Taxi need to be ON for the Pulse to work? Or, will the Pulse work with either or both Landing and Taxi OFF?
Does the Landing power ON also cause the Taxi lights to illuminate? Or, are the Taxi lights completely separate from the Landing?
Thanks again.
