Old 01-29-2015, 02:08 PM
Dean_aeroleds's Avatar
Dean_aeroleds Dean_aeroleds is offline
Default Updated Aerosun Vx Wingtip modification instructions
We discovered an error in the instructions for the RV-9/10/14 wingtip modification instructions that affected the RV-9 (but was correct for the RV-10/14).
The updated instructions are now online here: http://aeroleds.com/wp-content/uploa...ure-Rev_A1.pdf
Dean Wilkinson
CTO, AeroLEDs LLC
Old 02-10-2015, 06:16 AM
bruceflys bruceflys is offline
Dean, I am considering the Aerosun Vx for my RV-10 project.
First, why this modification? The instructions for the actual placement of the lights into the wingtip make no mention of the mod and do not even seem to need it.
Second, your website shows a price of $895 for a pair of Vx lights. Aircraft Spruce shows $174. Which is it?
Bruce
Panther - Building 2019
RV-12 - Flying 2016; Sold 2018
RV-10 - Sold 2018; Flying 2018
SeaRey - Flying 2012; Sold 2017
Old 02-10-2015, 07:10 AM
N546RV's Avatar
N546RV N546RV is offline
The $174 appears to be just the conversion kit, which I presume doesn't include the actual lights.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 02-10-2015, 07:24 AM
krw5927 krw5927 is offline
Because Spruce makes no mention of quantity, I had assumed the $790 was for each light, so almost $2k for a pair with conversion kits. Is this not the case?
Kurt W.
RV9A
FLYING!!!
Old 02-10-2015, 11:09 AM
The change to the installation instruction was to add a dimension for the RV-9 wingtip which is different than the RV-10 for making the cutout. The original version only showed the RV-10 dimension.
The lights are sold as a pair for $790 on Aircraft Spruce.
The conversion kit includes both the left and right fiberglass bucket inserts for enlarging the light cove.
Old 02-10-2015, 05:38 PM
bpattonsoa bpattonsoa is offline
If you have already cut your lens like me and then switch to the new lights, the RV-10 lens VA-193 is 61 bucks additional. Worth it, my first unnamed LEDs were RF bombs, on wig wag they were clearly the last noise to go away when adjusting the radio squelch.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 02-12-2015, 01:53 PM
To help clarify the below table, if you have an RV-7 or RV-8 with the W-715-1 wingtips, all you need is the lights. If you have an RV-9, or an RV-10, you will also need the appropriate conversion kit to enlarge the light cove. The RV-9 conversion is more expensive because we have to provide new lens covers since the Van's stock piece for the RV-9 is not large enough.
[/quote]
An RV-6 or RV-4 could use the Vx lights if the wingtips were changed to the W-715-1 wingtip part, which I was told will fit the RV-6 and RV-4 wings.
Dean Wilkinson
AeroLEDs LLC
Old 03-04-2015, 07:38 PM
kblack kblack is offline
Dean:
I'm planning to use the VX lights in my RV-7. Several questions:
1. I assume the VX lights wire per the "Four Lights" diagrams. Can you confirm?
2. The data sheet indicates each light draws 5A max at 12VDC. So, I gather the Landing Lights will draw about 3.3A each?
3. Are the Green and Blue lines for WigWag Sync low current signal? If not, what load needs to be supported by these lines?
4. Is the Yellow for WigWag ON also a low current signal? If not, what load do we need to support?
5. One of the "Four Lights" diagrams published on the AeroLED website shows a diode (looks like 8A 45V) between the Taxi and Landing light power lines. It looks like the purpose is to energize all lights anytime the Landing Light switch is ON. Another diagram has no diode. I assume it is OK to omit this diode if I do not want the Landing Light Switch to also energize the Taxi Lights?
These lights look to be pretty cool. Thanks in advance for any help you can offer.
Kliff
Granbury Texas
RV-7 QB (N74KB) - Flying
RV-10 QB - Empennage Started
Old 03-05-2015, 05:35 AM
Maxrate Maxrate is offline
Default Price
Dean,
Will you guys be running specials at SnF or OSH this year? Maybe a package deal..
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
Old 03-06-2015, 02:58 PM
Wiring diagram:
There are 5 wires per light:
Black 18 gauge = Ground
Red 18 gauge = Power input for landing light mode (steady on)
Yellow 18 gauge = Power input for pulse mode
Green 20 gauge = Synch wire (connect both L and R greens to each other)
Blue 20 gauge = Taxi power input to light up just 3 LEDs for taxi mode
If you have a vertical power system that will do the wig-wag, you won't need the yellow or green wires. The blue taxi mode wire is optional.
Each light draws 5A at 12V, so the set draws 10A.
The yellow wire is a power input for the pulse mode.
The four light diagram is for our other lights, not for the Vx.
Dean
Originally Posted by kblack View Post
Dean:
