02-26-2015, 05:41 AM
How good is Vans RV-7 tail intersection fairing
So, I have an RV-7 tail on my RV-6. The intersection fairing from the RV-6 is pretty much useless since the -6 does not have an offset in the vertical stab like the -7. I have seen the aftermarket options (which look great), but at $250 they are too rich for me.
My options are to buy a fairing from Vans or make one from scratch. For those that have purchased recently, how is the fit of the Vans fairing? Pretty good, or not even close?
If it is pretty good, then I'll just go that route and save the trouble. If the fit is bad I'll make one from scratch and save the cost of a new fairing.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
02-26-2015, 06:03 AM
Colin,
The fit is not terrible but no where close to where folks have made their own fairings.
The worst part of my fit was the leading edge to the horizontal stab. Folks say if you use a heat gun you can persuade the fiberglass to fit better
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
02-26-2015, 06:20 AM
Mine was from Vans in 2013, all of it fit OK but the front HS part had to be cut off and re done, I still spent one month on it.
02-26-2015, 06:28 AM
Factory out of the box
Little gap on leading edge needed flattened
After a few hours
I added lower enclosure/capture strips...added probably 10hrs
3 screws trailing edge of each side, 2 upper 1below, hold it in place. Vans fairing worked well for me
02-26-2015, 08:27 AM
Thank you for the replies. Overall it looks like the fit is ok, but not great. Still probably easier than starting from scratch. I think I will go ahead with the Vans part and tweak as needed.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
02-26-2015, 10:13 AM
02-26-2015, 11:15 AM
The thing about the fibreglass in Van's kits is the variability. Some are much better than others. That tail intersection fairing was less trouble for me than some of the other parts because it's easier to shape with heat.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
