Originally Posted by rleffler
In looking at the plans versus the pictures, it appears that your spars are cleco'd backwards. The front spar flange should face forward and the rear spar flange face aft. Then there won't be any overlap with the rib.
Don't worry you're not the first person that couldn't see the forest because all the trees are in the way. Sometimes when you get stumped it takes a fresh set of eyes to see the obvious. Usually when something doesn't fit right, the orientation on at least one of the parts is off.
bob
Disregard what I said. I thought the close up photo was of a different spot.
I agree, I would have thought that it should stop short of the spar flange as well.
Have you given Van's a call?
