Old 02-18-2015, 07:35 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default How to remove flap anti chafe tape ?
My rehab project has a clear tape on the curve leading edge of the flaps. It is very thin and won't peel off. Any suggestions for removal??
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 02-18-2015, 08:09 PM
Perhaps a heat gun will loosen the adhesive.
Dave
Old 02-18-2015, 08:48 PM
AlexPeterson's Avatar
Oh my, your problem brings back memories... I do not have good news - it was awful getting that stuff off mine after around 6 years. I made scrapers from plexiglas, and used a heat gun. There were many, many hours involved. The plexi scrapers worked reasonably well, but they were fairly narrow IIRC. Too wide and one can't get the pressure needed. I tried various solvents, but since mine is painted under the tape, I didn't want to get too aggressive.
For those not following why this is a problem - the polymer crazes and cannot be pulled off. Small shards come off instead.
Patience....
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 02-18-2015, 09:01 PM
Kyle Boatright Kyle Boatright is online now
http://www.vansairforce.com/communit...t=uhmw+removal
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-19-2015, 12:13 AM
rjbob rjbob is offline
Originally Posted by Kyle Boatright View Post
Thanks for the GREAT link, Kyle!
An added plus in the thread is info on a product that is a viable alternative to the tape most of us use.
Bob Edison
RV-7 N749ER...(GO NINERS)
ATP CFI-II-ME
Anchorage, Alaska
Let me know if you're RVing to Anchorage!
Old 02-19-2015, 05:17 AM
DanH's Avatar
DanH DanH is offline
In the truck business we peel a lot of vinyl lettering. On a commercial level, the typical aluminum truck box is stripped by placing a space heater inside, and heating until the outside of the box is about 200F.
If the material is too old to peel, attack it (gently) with a sharpened plastic ice scraper or similar.
Removing the leftover adhesive is painless with the right stuff. Go online and order a bottle of Rapid Tac "Rapid Remover".
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-19-2015, 05:59 AM
strahler13's Avatar
strahler13 strahler13 is offline
And when you are done, replace with stainless steel tape. Looks great and you won't have the same problem down the road.
Mark Strahler
RV-6 (Purchased flying)
KFFC-Peachtree City, GA
Old 02-19-2015, 07:26 AM
gtmule gtmule is offline
I was hoping Kyle would post this so I didn't have to find it. I used his method and can report that:
A) It works great
B) You need a plug-in drill motor, or you'll spend more time charging batteries than removing tape
My flaps are white so I bought some cheap white vynl vehicle wrap, 12" X 60" from amazon and cut strips to use as flap tape. Working great so far, and looks great as well.
Macon, GA (KMCN)
RV-7, Niner Fife Victor
Old 02-19-2015, 07:28 AM
Capfo Capfo is offline
I replaced mine last month and the eraser wheel is the ticket! Took me all of about two hours.
Chris
RV-8
KCXO
https://youtu.be/mBpIBBEA9WM
http://youtu.be/IB4jLrx0gWg
