Old 11-20-2009, 04:01 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Default RV-7A V Stab Mounting Issues
I've finally resolved my mounting issues with the horizontal stab and now have new issues with the vertical stab.
I've followed the blue print and have exactly 7-11/32" between the top of the F-718 Longeron and the top of the lower Hinge bracket.
Next I clamped the F-781 to the H Stab, using the 3/8" measurement from the bottom of the plate to the center of the holes on the HStab.
Here comes the problem. When I raise the front Spar of the V Stab up high enough to get all three rudder hinges in alignment, I do not have sufficent edge clearance for the rivets attaching F-781 to the VStab (VS-702). (If I would have waited to trim off the 5/8" indicated on the plans I wouldn't have this problem)
Additionally, the front of the bottom skin of the V Stab sits a bit (~1/4") higher than the fuselage skin. Looking at other pictures I've found on VAF, this appears a bit high.
I called Vans and their best suggestion was to order some 063 and make a longer F-781 myself..... while I can certainly do that, I thought that I'd check with the experts on VAF to see if there was a different solution that I'm missing.
Thanks again for your help and patience,
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 11-20-2009, 04:33 PM
Rick_A's Avatar
Rick_A Rick_A is offline
I had a similar problem and had to make a custom attach plate (F-781). The pre-drilled holes in the stock part did not give adequate edge distance on the VS.
Making the part was actually pretty easy.... once I got the 063 from Vans.
I agree that the instruction to trim 5/8's off the VS was also the source of my problem.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 02-18-2015, 10:52 AM
Yazaman Yazaman is offline
Cool, Im not the only one with this problem... Of course I found it at 9:15 (after Vans Help line closed for 6 hrs).
I pressed on and made my own plate as well with shop stock. Details are here...
http://www.mykitlog.com/users/displa...g=204190&row=2
