02-17-2015, 12:55 PM
Originally Posted by Lionclaw
Very cool! Now can we get SV to connect to a mobile hotspot and update its databases?
I am going to guess that is a slow proposition, as my monthly SV database and chart updates take hours if I go ahead with all charts and all 50 states, so the SV would have to be powered up for an awfully long time.
02-17-2015, 01:02 PM
Originally Posted by dynonsupport
I just checked the on line store and can't find the adapter.... .
02-17-2015, 01:23 PM
Pick up that old relic the telephone. Worked for me.
Kurt W.
RV9A
FLYING!!!
02-17-2015, 01:32 PM
Only downer is the need/annual expense to upgrade to ForeflightPro (didn't see a need to do so before)
02-17-2015, 01:57 PM
Originally Posted by kverges
If one already uses a Stratus ADS-B receiver, is this an either-or proposition?
Yes, either Stratus or Dynon Skyview, but not both simultaneously on the same device. But you can connect separate iPads or iPhones to each... ;-)
And ADS-B data isn't currently passed to ForeFlight.
- Josh
02-17-2015, 02:17 PM
I continue to be happy with my Dynon purchase!
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
02-17-2015, 02:24 PM
I think this option was only available through Gx3 using Garmin Pilot, but not sure.
I have an AFS 4500 in my RV8 and recently got Foreflight.
I'm looking to upgrade the AF 4500 to something, maybe a AF 5600 Touch or?
Since AFS is afflliated with Dynon, maybe we will see a FF - AFS compatible setup. Time will tell.
This is an awesome trend. I hope others will partner like this.
Charlie
02-17-2015, 03:58 PM
location, location, location
Can the WiFi adapter plug into the rear panel USB connections? I have the one included in the wiring bundle mounted in the panel to hold the thumb drive with all the charts and plates. No connectivity issues with a panel and SkyView between the adapter and my iPad?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
02-17-2015, 05:58 PM
Bubblehead - Yes it can.
02-17-2015, 06:48 PM
Originally Posted by krw5927
THIS IS AWESOME!!!
Quick questions:
1) How many iOS devices can connect at a time?
2) Do weather and traffic get passed to Foreflight from the SV-ADSB-470 if installed?
1) A bunch. The technical limit is some base 2 number, maybe 255. Bandwidth becomes a concern at some point before that. But practically speaking, you can have more iPads connected than there are seats in any RV
2) They don't in this release. That's not a promise that they ever will, but you and others are imagining possible future expansion features that are within the realm of possibility. Make sure to let ForeFlight know what you'd like to see too!
