Old 02-13-2015, 05:03 PM
AltonD's Avatar
AltonD AltonD is offline
Had a similar issue. Air in the lines. Try one of these. I hooked up a line from the top of the reservoir and just let the bleeder go till I had good overflow from each side. Also, to remove excess fluid from the reservoir, I use a turkey injector syringe from the aviation department at Winn Dixie.
As a added benefit, it sure makes bleeding brakes easy.
https://www.aircraftspruce.com/catal...leedertank.php
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 02-13-2015, 05:11 PM
Have you checked the brake and cylinder part numbers? Maybe somehow you have the wrong brake or cylinder.
Dave
Old 02-13-2015, 05:33 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Dave
I am not sure what that means. Can you elaborate? The wheel brake assemblies are Cleveland. I don't know what the cylinders are in the pedals, but they are gold.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 02-13-2015, 05:41 PM
sblack sblack is offline
On my 4 project I noticed that the mounting bracket for the brake assembly, which is a steel disk with 4 holes, was not welded on to its mounting tube properly. It is crooked. So the pads will not be parallel to the disc. I am going to fix that before I assemble the landing gear. I think that this will substantially reduce the contact area and therefore the stopping power.
Could that be your problem? Just a hare brained theory, but you posted looking for ideas and one never knows.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 02-13-2015, 05:54 PM
ccsmith51's Avatar
I believe that is OK. When I put everything back together yesterday I made sure everything moved in and out freely and that the pads appeared to be parallel to the discs.
Chris Smith
Old 02-13-2015, 05:56 PM
ccsmith51's Avatar
My A&P friend and I spent a lot of time bleeding the brakes and think that we got all of the air out. The pedals feel firm and we saw no bubbles.
I have never heard that the reservoir could be too full. Can you elaborate on that?
Chris Smith
Old 02-13-2015, 06:16 PM
AltonD's Avatar
Too full is not an issue. Other than when it heats up and overflows and makes a mess.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
Old 02-13-2015, 08:28 PM
How about the pedal geometry relative to the cylinder? Does the pedal provide the proper leverage? Brakes are pretty simple. If the pad is good and the disc is good then they aren't being pushed together hard enough. Either you aren't putting enough pressure into the system because the cylinder isn't being pressed hard enough (geometry?, weak feet?) or there are leaks somewhere. Or there is not enough travel to squeeze the pads tight! Can't think of much else.
Scott Black
VAF dues 2020
Old 02-13-2015, 08:48 PM
wirejock's Avatar
wirejock wirejock is offline
Default Brakes
Something sounds wrong. If you're pressing hard on the pedals, that hydraulic pressure is being blocked somewhere. I've seen debris get in lines but usually it shows up as pulling to one side. Also seen pistons get stuck. If it's the same both pilot and co-pilot then the problem has to be downstream. Can't be air. Usually air feels like a soft pedal. If they are new pads and not bed properly, that would be a symptom. Same of they were covered in oil. Keep looking.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-13-2015, 09:02 PM
AltonD's Avatar
Larry brings up a good point. Any chance there is a parking brake installed that is not fully releasing? Since you are not the builder, if installed, it is between the calipers and each master cylinder as a single unit.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
