Old 02-13-2015, 02:24 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Weak brakes...
I, and my friends, are stumped on this one.
The brakes on my RV-6 have never held very well since I purchased it last August.
About 20 hours ago I replaced the pads and discs. It still didn't hold very well and I thought that perhaps I had not broken the pads in well. I would have to stand on the brake pedals to the point I was forcing fluid past the master cylinder O-ring and still the brakes would not hold past about 1,600 RPM.
Yesterday I pulled everything apart and sanded the pads per recommendations to remove any glaze, roughed up the discs, and put it all back together. I flew and upon landing got on the brakes good. I taxied back and took off and landed and did the same.
Today I went flying that the brakes are the same, won't hold past about 1,600 RPM.
The pedals feel solid, not mushy. There are no leaks in the system except when I press so hard that I think I might break the pedals.
So, any thoughts on what I can try next? The same brakes on my RV-4 we so strong that a couple of times I almost put it on the nose...
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 02-13-2015, 02:42 PM
Larco's Avatar
Larco Larco is offline
There is a published procedure for breaking in the pads and this sounds like it was not done correctly. Some say that just stand on the brakes when doing the landing roll out but in my experience this does not work. I have the proper procedure written down at the hanger as a hand out but am at home now. Suggest going to the brake pad manufacture webpage and downloading the info. The scenario that you are experiencing is not new to the RV world but seems to go away as soon as people are coaxed into doing the break in correctly.. Larry
Old 02-13-2015, 02:44 PM
Infidel's Avatar
Infidel Infidel is offline
Do both brake sets feel equal when applying pressure? If so, my uneducated guess would be the shoes and or rotor.
Old 02-13-2015, 02:47 PM
flyboy1963's Avatar
Default funny how often this comes up?
thread from a few days ago on a similar problem.
http://www.vansairforce.com/communit...&highlight=ugh
....and if they are Cleveland; possible breakin procedure.
http://www.aircraftspruce.com/catalo...ingprocess.pdf
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 02-13-2015, 02:51 PM
ccsmith51's Avatar
Default Procedure
I have Rapco pads that I purchased from ACS. On their web page it has a PDF with the proper procedure. Below is what it says, and which I performed:
RAPCO, Inc. Brake Disc Wear-in Procedure
The normal break-in procedure for brake discs using the Rapco, Inc. RA164- discs, is to get the friction material hot (Approx. 850 Deg. F.) by performing the following:
? Use proper maintenance techniques by insuring that the friction material is completely clean and dry of all solvents and hydraulic fluid
? Perform a moderate-speed taxi (10-15Kts ground speed), insuring that you have proper braking (There will be very little brake action at first).
? Allow the brake to cool by taxiing across the airport or down field, without using brakes. If you are not going to fly the aircraft during the break-in procedure, then allow the brakes to cool for 45 min. until the next high-speed taxi stop.
? Once you've established positive brake action, you can proceed to a full-stop landing using significant braking. (Short field landing procedure). At this time the pilot should notice the brakes starting to grab more. If this is sufficient braking action, there is no need for another stop cycle.
? Perform another short field landing, leaving the landing gear extended throughout the landing pattern. This allows the brakes to cool properly before the next heat cycle. After this landing you should have significant brake action.
Chris Smith
Old 02-13-2015, 03:28 PM
turbo's Avatar
turbo turbo is offline
I find if you put your toes to the top of the pedal you will get a bit more power.
Otherwise you may have a strong engine. Results may vary.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 02-13-2015, 04:15 PM
DHeal DHeal is offline
Are your brake disks standard issue or stainless? I seem to recall that stainless discs don't offer the same gripping power (friction) as standard steel discs.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 02-13-2015, 04:23 PM
ccsmith51's Avatar
Both brakes feel the same. What I have not tried is flying from the right side and using the passenger side pedals. When we bled the brakes last time we tested. It's sides and he felt the same. I will do a run-up from the passenger side next time and see if it is thes same, which is what I expect.
Chris Smith
Old 02-13-2015, 04:24 PM
ccsmith51's Avatar
Tried that but the pressure required is still too much and can't hold past about 1,600 RPM.
Chris Smith
Old 02-13-2015, 04:25 PM
ccsmith51's Avatar
Standard steel.
Chris Smith
