Old 02-12-2015, 07:09 AM
Iluke Iluke is offline
Default Band Saw blade recommendation
Hi everyone. Just (finally) bought a band saw and I'm looking for recommendations on a blade that would work better cutting aluminum that the one it came with which works but is a bit course (don't know the actual tooth count) and leaves a jagged edge.
My saw takes a 72 inch blade of between 1/8 and 1/2 inch width. On slow speed it runs 16 feet/min.
Any suggestions?
thanks,
Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
Just hung the engine!
2020 dues paid
Old 02-12-2015, 07:27 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Ivan, I've used this blade for aluminum for 23 years, love it! http://www.sears.com/craftsman-1-4-x...p-00902625000P
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-12-2015, 07:54 AM
N941WR's Avatar
N941WR N941WR is offline
Since you are asking about blade size, I would go with an 18 TPI in the 1/4" size. Buy a couple of them and get a few in 1/2" just incase you need to do some long straight cuts.
To clean up the cut marks, I have one of these Delta bench sanders with 80 grit on the disk and 120 grit on the belt. After dressing my cuts on this, I finish them on the deburring wheel spun by my drill press set to the lowest speed.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-12-2015, 08:08 AM
wirejock's Avatar
wirejock wirejock is offline
Default Blades
I use two. 14TPI for most cutting. 7TPI for angle and bar stock. Cut outside the line and sand using a disk/belt sander. The thick stock will dull a fine blade. Take your time and watch the kerf. The cut can wander pretty quick if you feed too fast. If it happens, back up a tiny bit and feed again.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-12-2015, 10:49 AM
thanks.. 7TPI for thicker stock surprises me. I guess I was thinking the finer the better. Good to know.
And how about blade width. They sell them as small as 1/8 inch and those are advertised as being better for cutting curves-- A smaller minimum radius that the 3/8 that came with the saw. But I'd guess that the trade-off of a narrower blade would be it being harder to cut a straight line with it? Does that make sense?
Ivan Luke
Hope Valley, RI
RV-7 SB
2020 dues paid
Old 02-12-2015, 10:58 AM
380mxc's Avatar
380mxc 380mxc is offline
Default rule of thumb
The basic rule of thumb for band saw blade pitch is three teeth in contact with the material.
Tim Emig
RV7
As I hurdled through space, one thought kept crossing my mind - every part of this rocket was supplied by the lowest bidder.
~ John Glenn
Old 02-12-2015, 12:09 PM
wirejock's Avatar
Default TPI
YMMV. I'm breaking the 3TPI rule. It just seems like the 14 cuts so slow through thick stock, it gets hot and dulls fast. New blades too. The 7 cuts quicker and does leave deeper scars but cutting outside the line then sanding up to the line removes them.
You won't cut many curves but 1/4 is about right for most of what we do.
Larry Larson
Estes Park, CO
Disclaimer
Old 02-12-2015, 12:50 PM
N941WR's Avatar
Yes, but we really don't cut through thick stock. The thickest AA in the kit is still pretty thin.
I corrected my post above, I used 1/4" 18 TBI blades and they worked great on the sheet aluminum and OK on all the AA.
Bill R.
SC86 - Easley, SC
Old 02-12-2015, 12:53 PM
ninerhawk ninerhawk is offline
Default Band saw blades
I ended up buying a custom blade for my Craftsman bandsaw and had great success cutting all kinds of aluminum. For exmaple, bandsawbladesdirect dot com allows you to spec out what you want at a competive cost, and at the blade length you specify. Blade speed is an important factor. Without speed adjustment, I wanted something with a higher tooth count.
Howard Kaney
RV-9A
West Bend, WI
fuselage/FF
