I used Deans plugs from the local R/C model store to hook up the wiring at the servo pigtails.
The connectors were modified to make a two pin non polarized unit, and a three pin polarized one.
I used the three pin unit for the feedback pot, and the two pin for the motor----would allow me to reverse the motor direction if needed without having to cut into existing wiring.
Finally after run tests to make sure it was all correct, I tied the two halves of the connector together with lacing cord, and mounted the connectors to the airframe with a zip tie.
The wiring runs forward along the side panel, to the junction block under my seat where it is hooked up to the control stick grip switches.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
