Old 01-31-2015, 08:27 PM
wirejock's Avatar
wirejock wirejock is offline
Default Akzo priming
Not a primer war question.
I'm considering changing to Akzo for the fuse since my SW P60G2 is almost gone and came up with a wild idea.
Has anyone ever tried tinting Akzo 463 with epoxy tint? It is epoxy right.
I know it's green so the color will probably be weird but maybe a very dark black or charcoal?
It would eliminate painting the interior, save some weight and give a durable finish with corrosion protection.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-31-2015, 08:55 PM
diamond diamond is offline
Great idea, but before I could feel comfortable doing that, I would have to hear from the manufacturer themselves that the integrity of the primer would not be compromised. Just curious, what's wrong with the green color that it comes in?
Old 01-31-2015, 09:46 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default primer vs top coat?
Primers are just that - they are not top coats. Exect UV to change the color of the primer wherever it might shine on it, and woe to you if you hit it with a strong detergent.
As far as I know, it cannot be tinted - but it can be mixed with same-brand primers to get different colors.
Primer is also somewhat porous, to allow the top coat to adhere. At least the PPG DPxxLF is. Azko has a different sfc, as does the primer from Poly Fiber.
Azko is easy to mix: 1 to 1 and get after it!
Now, if you top coat it with a clear coat of some sort, it just might work.
DanH might jump in here and declare it OK - if he does, then you can carry on with Plan A. He is a pro, and I am the opposite.
Carry on!
Mark
Old 01-31-2015, 10:58 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
I'm priming with Akzo, and it is great as a primer, but I don't think you would be happy with the surface as a top coat. It seems like it would pick up dirt easily, and be a bear to clean.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 02-01-2015, 08:31 AM
wirejock's Avatar
Default Tinting Akzo
I did say it was a crazy idea. Thanks for all the replies.
Larry Larson
Estes Park, CO
Disclaimer
Old 02-01-2015, 02:40 PM
rjbob rjbob is offline
If you like the primer look, is a clear finish coat an option?
Bob Edison
RV-7 N749ER...(GO NINERS)
ATP CFI-II-ME
Anchorage, Alaska
Let me know if you're RVing to Anchorage!
Old 02-01-2015, 02:46 PM
wirejock's Avatar
Default Clear
One option for sure. Probably a satin clear. I really prefer something darker though.
Plenty of time to research.
Larry Larson
Estes Park, CO
Disclaimer
Old 02-01-2015, 03:15 PM
You're thinking outside the box...I can't wait to see what you come up with.
Bob Edison
ATP CFI-II-ME
Anchorage, Alaska
Old 02-01-2015, 06:30 PM
F1Boss's Avatar
Default enamel color number to match WW2 primer
If you want the primer color for your interior in an enamel, I have the color numbers for you - it's a dang Jeep color! I did my interior that way. Pics available too.
I sat in Gerry Beck's P51B way back when and had to do the same thing he did. In the end, I do not care for the black panel - I think grey would have been a better choice. Fingerprints, ya know...
BTW the P51B cockpit is about the same width as an RV4. Those were NOT very large airplanes!
F1boss at gee mail dot com
Carry on!
Mark
Old 02-01-2015, 07:00 PM
wirejock's Avatar
Default Color
I'm not crazy about green for the cockpit. Nothing against it. I have a green car.
I dark, neutral and non glossy but not black. It sounds like Akzo is UV sensitive so I need to shoot a color over it.
Larry Larson
Estes Park, CO
Disclaimer
