  #31
Old 01-31-2015, 07:00 PM
Joe,
There is at least one other thread on this, and I recall it saying yes to both your questions.
Rich
Old 02-01-2015, 03:53 AM
f1rocket's Avatar
f1rocket f1rocket is offline
http://s7d9.scene7.com/is/image/Genu...ompany/1702697
As soon as my local NAPA store opens Monday morning, this will be going into my RV-12 in the engine compartment. No more Ducati VR's for me. I will mount it with conductive grease and I am planning to make a fiberglass plenum that blows the cooling air across the fins. I may change the mounting location to improve cooling but I am NOT moving it into my cockpit. In my airplane, I am not shoving two always hot wires into the same firewall grommet as control cables and bringing them into my cockpit. In my opinion, that MIGHT fix one problem but increases the risk of another problem (FIRE). I simply prefer to not do that. YMMV.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 02-01-2015, 05:13 AM
Mich48041 Mich48041 is online now
Randy,
That voltage regulator should work. But it is not plug and play. The Ducati connector will not fit and the wires will have to be switched around. And the mounting holes most likely will not have the same spacing. Of course you probably knew that.
Similar looking regulators are for sale on eBay for half of the NAPA price. Who knows if they are identical parts or not. Search for AM101406
Joe Gores
RV-12 Flying
Old 02-01-2015, 05:33 AM
BigJohn BigJohn is offline
Randy,
I applaud your efforts, let us know how it goes. Just a point, the two "always hot" wires you are referring to are the AC wires from the alternator. You don't have to run them through the control cable opening, you can make a new hole for them, as I did. Also they are well protected by the big braided sheild, and in fact only carry the alternator output, which most likely couldn't push enough current to start a fire even if directly shorted.
Good luck with your mod, let the forum know how it works out.
John
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
?Master Pilot? Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 02-01-2015, 05:40 AM
tomkk's Avatar
tomkk tomkk is offline
What's NAPA's part number for that VR? Thought it might be the 170 number in the URL but that didn't work.
Tom
Port Orange, Fl
EAA #51411
Old 02-01-2015, 06:16 AM
Walt's Avatar
Walt Walt is offline
Looks like the same regulator used on the SD-8
http://www.bandc.biz/pdfs/PMR1C_outline_REV_D.pdf
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-01-2015, 06:39 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Need Regulator/Rectifier
The VR for this application is both a VR and Rectifier. The B&C unit is just the voltage regulator.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 02-01-2015, 06:52 AM
Hotscam Hotscam is offline
I see 12 Amps max which is way too low.
20-22 is safe
Jack Netherlands
PH-SEP and PH-SES
RV12 #120519 and #120790
Hobbs 700+ hours and 400+ hours
Dual SV1000 Skyview 15, Pocket FMS and Powerflarm 6.0 (ADSB)
RV10 PH-USN Hobbs 350 hours
Old 02-01-2015, 07:00 AM
Bill_H's Avatar
Bill_H Bill_H is offline
I also intend to drill a new hole in the firewall just for this wire, with grommet and sealant.
Old 02-01-2015, 07:43 AM
NAPA Part Number: SME 7068102
Joe Gores
RV-12 Flying
