Old 01-28-2015, 05:16 PM
Fly2KiteSurf Fly2KiteSurf is offline
Default Does the RV-10 and/or RV-14 firewall mounted oil cooler fit on the RV-7 firewall
1. Does the RV10 and/or RV14 firewall mounted oil cooler fit on the RV7 firewall?
2. If the larger physical size of the 10 & 14 oil cooler prohibit it from being used on the RV7, does anyone know of a ready-to-go kit that allows a firewall mounted cooler on the RV7 with minimum fabrication?
3. Please post photos of firewall mounted oil coolers on RV7's?
Thanks guys!
Sean Reynolds
Purchased RV-3 project, restored, flew for 18 months, sold. Purchased flying RV7, flew for 5 years, sold. Currently building RV-14 quick build.
Old 01-28-2015, 05:23 PM
DarylT's Avatar
DarylT DarylT is online now
Default Why?
Are you concerned about cooling? Thinking of going bigger. I did and kind of wish I didn't. I live in central Texas and went with a larger oil cooler and find it difficult to get the oil hot during the cooler months. I have it tapped up totally and still can only get it above 180 with an extended climb above 6000 feet. My friends that went stock have no issues in the summer and still tape up theirs as well. Lets see where others weigh in on this.
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 01-28-2015, 05:33 PM
Guess I should have clarified. Thanks for pointing that out.....
I am not interested in a larger oil cooler. I just don't like the weight and stress up on the cooling baffles and repairing cracks and patches, etc...
I can fix the current cracks on the -7 I just purchased, or relocate the oil cooler to the firewall?
Thought about using the 10 or 14 oil cooler bracket if it fits (or similar bracket if available) on the firewall of my -7, but use the standard smaller oil cooler.
Hope that clarifies things.
Advise appreciated.
Sean Reynolds
Old 01-28-2015, 08:42 PM
UnPossible's Avatar
UnPossible UnPossible is offline
I mounted the larger oil cooler from the 10 on the firewall of my 7A.
I also installed a 4" butterfly valve to control the airflow through the cooler.
This setup has worked very well for me for nearly 150 hours now.
Hope this helps,
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 01-29-2015, 07:18 AM
Randy Randy is offline
I mounted the RV10 oil cooler bracket to the firewall of my RV7A along with a 4" butterfly valve that will be controlled via cable from the cockpit.
The bracket from the RV10 kit has the inlet hole offset to the the inboard side which would cause interference with the scat tube hitting the motor mount tube.
In my case I solved this issue by moving the hole over to the other, outboard side. Moving the hole turned into a bit of a miserable welding job and I suspect the alloy is 2024 alclad, which is considered a non weldable alloy.
I got it done and believe it is strong and serviceable. I do not recommend doing it via welding. The hole should have been moved over via sheet metal work, cutting and riveting etc. If you were to go to that much trouble you might as well just make the thing yourself.
Mine holds the legendary 8432R oil cooler and I look forward to seeing this combination at work in this summer's AZ temperatures. With everything in position the bottom of the cooler is very close to a motor mount tube but I did not have to bend anything to gain clearance.
Randall in Sedona
IO-375, WW RV200
Old 01-29-2015, 10:25 AM
What's the best source for these large diameter butterfly valves?
Old 01-29-2015, 10:34 AM
rleffler's Avatar
rleffler rleffler is offline
Avery Tools
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-29-2015, 11:19 AM
380mxc's Avatar
380mxc 380mxc is offline
The 10 cooler fitted on a 7 with some modifications
Tim Emig
RV7
As I hurdled through space, one thought kept crossing my mind - every part of this rocket was supplied by the lowest bidder.
~ John Glenn
Old 01-30-2015, 10:03 AM
Thanks, Bob. Avery is, for some reason, not a place I would intuitively look for this part... DOH! :-)
Old 01-30-2015, 10:24 AM
rleffler's Avatar
There was another company manufacturing and selling them. One of the owners passed away and the remaining owner operated the business for awhile. Then he turned over sales to Avery.
Bob Leffler
