Old 01-29-2015, 02:50 PM
Z-EDD's Avatar
Z-EDD Z-EDD is offline
IMG_0654 by Ed Fleming, on IMG_0657 by Ed Fleming, on IMG_0654 by Ed Fleming, on IMG_0619 by Ed Fleming, on IMG_0619 by Ed Fleming, on IMG_0619 by Ed Fleming, on Flickr
Ed Fleming
RV-7- Flying as of 12/23/20
Harare, Zimbabwe
Old 01-29-2015, 02:55 PM
Z-EDD's Avatar
Default This was an awesome moment!
IMG_0660 by Ed Fleming, on FlickrIMG_0660 by Ed Fleming, on FlickrIMG_0660 by Ed Fleming, on FlickrIMG_0660 by Ed Fleming, on Flickr
Ed Fleming
Harare, Zimbabwe
Old 01-29-2015, 03:07 PM
Z-EDD's Avatar
Talking And the skeleton comes together permanently
IMG_0677 by Ed Fleming, on Flickr
Paul helped to buck the rivets, thanks Bud!
IMG_0678 by Ed Fleming, on Flickr
IMG_0681 by Ed Fleming, on Flickr
IMG_0683 by Ed Fleming, on Flickr
IMG_0684 by Ed Fleming, on FlickrAnd what a satisfying moment! These aren't drilled yet. I had to go to work for a couple of weeks and did not want to rush it, so that'll be waiting for me when I get back. Then I need to get the right wing to the same stage.
Ed Fleming
Harare, Zimbabwe
Old 01-31-2015, 06:50 AM
VPYVO VPYVO is offline
Default Looking good
Hi Ed,
Looking good.
Will be in Zim in September for our Saints 40th reunion. Planning on catching up with the other RV guys then. Will add you to the list if I may and meet up.
Been too long between drinks at the MFC!
Cheers Rob
Rob Rickards
Melbourne Australia
RV7 VH-RRA flying Sept 2017
Sept 2019 180 hours
=VAF=. 2019 Donor
Old 01-31-2015, 11:04 PM
Z-EDD's Avatar
Thumbs up
Originally Posted by VPYVO View Post
Hi Ed,
Looking good.
Cheers Rob
Great Rob, look me up when you're here, I'm always up for a beer at MFC!
Ed Fleming
Harare, Zimbabwe
Old 05-04-2015, 02:29 PM
Z-EDD's Avatar
Default Two Wings!
Getting the right wing into the stand and then working on the leading edge
IMG_0698 by Ed Fleming, on Flickr
IMG_0701 by Ed Fleming, on Flickr
Caitlin is always very helpful with clecos!
Ed Fleming
Harare, Zimbabwe
Old 05-04-2015, 02:38 PM
Z-EDD's Avatar
Default And on to the tank
IMG_0708 by Ed Fleming, on Flickr
IMG_0710 by Ed Fleming, on Flickr
The well known "Checkoway method" of drilling the rear baffle. This shows the five holes that can be reached on the inboard Bracket. Used a 12 inch bit to drill these.
IMG_0711 by Ed Fleming, on Flickr
And here's the access to the outboard bracket. Yes the 12 inch bit got away from me a as I withdrew it. Looks worse than it is.
IMG_0712 by Ed Fleming, on Flickr
And this is after removing the skin and ribs and drilling the remaining brackets.
Very easy and accurate method.
Ed Fleming
Harare, Zimbabwe
Old 05-04-2015, 02:42 PM
Z-EDD's Avatar
Default Inboard rib prep
IMG_0718 by Ed Fleming, on FlickrIMG_0718 by Ed Fleming, on FlickrIMG_0722 by Ed Fleming, on Flickr
Ed Fleming
Harare, Zimbabwe
Old 05-04-2015, 02:49 PM
Z-EDD's Avatar
Default More tank stuff
IMG_0808 by Ed Fleming, on Flickr
IMG_0809 by Ed Fleming, on Flickr
IMG_0810 by Ed Fleming, on Flickr
IMG_0725 by Ed Fleming, on Flickr
IMG_0811 by Ed Fleming, on Flickr
This is where the sender will mount in the left tank, through the rear baffle and into the second tank bay. I used the spare cover plate and match drilled it to the rear baffle before using my band saw to cut out the stiffener ring. Although I match drilled it to the outside, I will mount it inside, with dimples in the baffle and countersinks in the stiffener as per the ribs.
Ed Fleming
Harare, Zimbabwe
Old 07-28-2015, 02:41 PM
Z-EDD's Avatar
Default Progress on the tanks
IMG_0744 by Ed Fleming, on Flickr
Dimpling the tank skins
IMG_0743 by Ed Fleming, on Flickr
Standard pickup in the right tank.
IMG_0739 by Ed Fleming, on Flickr
Anti hangup guides Mark 1.
IMG_0747 by Ed Fleming, on Flickr
How's my dimpling?
IMG_0749 by Ed Fleming, on Flickr
First prosealing
Ed Fleming
Harare, Zimbabwe
