11-13-2013, 10:28 AM
Originally Posted by bkilby
Anyone have a part number for a plug to screw in the sump drain? Might be handy to have on a trip if you find a drain leaking and don't have another drain/o-ring to replace it
Any 1/8" NPT plug will do. Probably only a couple dollars at your local home improvement store in the aviation plumbing aisle.
If you want to spend a few more dollars for a drop-in replacement to have on standby in the repair kit, Spruce has them here:
http://www.aircraftspruce.com/pages/...rainvalves.php
It's part number CAV-110. Vans has them too, same part number.
Kurt W.
RV9A
FLYING!!!
04-15-2014, 06:03 PM
I fought this issue for 5yrs. Then an A&P friend of mine suggested I change the regular brass fuel drain with a Stainless Steel fuel drain. I spent the extra $$$, bought a set of them and Viola, I have not had a fuel drain leak of any kind in the last 3 yrs.
04-16-2014, 10:23 AM
What issue were you chasing? If you have some schmutz or an aluminum chip on your fuel drain O-ring causing a leak, how would a stainless version be any better than brass?
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
07-20-2014, 10:14 AM
Long build time drain O-ring deterioration
After 'bumping' the drain several times after checking the sump I finally pulled the drains to clear any filings only to find both trash AND very bad O-rings.
After 7 years of building it never occurred to me that the O-rings would need replacement from just sitting in the parts bin. McMaster Carr Viton O-rings ordered
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
07-20-2014, 08:22 PM
Mine too. Phase 1. One started a solid stream of fuel right after a sump check prior to flight. Scrambled to come up with a 1/8" NPT capable plug.
On removal I found a completely dry rotted ring that broke into multiple pieces when I tried to remove it. The other wing was the same way. New O-rings plus spares in the travel kit.
Bill Pendergrass
ME/AE '82
07-20-2014, 08:49 PM
Lowes has them
Should be a 1/4" NPT plug. Don't have a part number.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
01-26-2015, 06:50 PM
My left tank quick drain gave out right after I read this thread. I replaced it with a 1/8" NPT pipe plug. I 'googled' BUNA N and Viton,
http://www.metrogasket.com/o-rings/m...tion_guide.htm the two common materials used in O rings. The BUNA is good to -40F to + 250. the Viton is -20F to + 400. They are both tolerant of ethanol and methanol, however the BUNA isn't so good with Acetone? I use Acetone to clean parts, so I might have killed the original O ring years ago when I built the wings, it just took this long to fall apart.
I got several of both, but I reassembled with the original type BUNA O ring. 1/4" OD, 1/8" ID 1/16" thick. Anyway, I have spares in my flight bag now.
I spilled maybe 2 or 3 tablespoons of gasoline making the change, the tank was more than 1/2 full. Just get everything ready and work fast.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
01-26-2015, 08:40 PM
Sump drains
For the proper stainless steel sump drains with the good O-rings check Safe Air CAV110 SS
09-17-2015, 05:20 AM
When replacing a drain fitting, I take it that you do not use any kind of sealant on the threads. No tape.
Just use the bare fitting, correct?
Flying RV-8 N880BC
2019 Dues - happily paid.
09-17-2015, 07:29 AM
I use fuel lube.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
