  #11
Old 01-26-2015, 09:45 AM
N402RH's Avatar
N402RH N402RH is offline
Look at the post before yours, it shows the power on pin 1 and ground on pin 9.
Rob Hickman
Advanced Flight Systems Inc.
N402RH RV-10
Old 01-26-2015, 10:51 AM
RV7A Flyer's Avatar
Originally Posted by wirejock View Post
Did you guys run the power wires in the D-sub?
Yes, and redlined the appropriate pages in the installation manual.
Makes for a cleaner installation, IMO.
Old 01-26-2015, 11:13 AM
6adan 6adan is offline
Ok, I saw that but thought it was for the AFS but if will work for mine that is good.
Old 01-26-2015, 11:54 AM
N402RH's Avatar
The AFS uses the Dynon servos and our control module is designed for both Skyview and AF-5000 systems. The network and remote components are now the same for AFS and Dynon.
Rob Hickman
N402RH RV-10
