  #11
Old 01-20-2015, 05:44 PM
sblack sblack is offline
You can use the winch but have it hooked to a towbar that attaches to the mains. Then you'd have to hold the tail down. But I have a hard time believing that if you added up the shear strength of all the fasteners holding the tailwheel bracket to the fuselage that it wouldn't be far greater than any towing force. Ask Vans.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 01-20-2015, 08:45 PM
N15JB N15JB is offline
This was discussed in an earlier thread, perhaps 1-2 years ago. Vans response was that the tail tie down point was not designed for horizontal loads.
Jim Berry
RV-10
Old 02-01-2015, 02:04 PM
SteveL SteveL is offline
Thumbs up check this thing out
Hey Bob,
When you get a chance go to www.ACAIRTECHNOLOGY.com and take a look at that fancy gizmo. I just watched a guy pull a Stearman around with it and the web side says they have one that will work with wheel pants.
Old 02-01-2015, 09:22 PM
SHIPCHIEF SHIPCHIEF is offline
.....ohhhhhh
a Hangar W I I I I I I NCH!
To the Winch, Wench! (with apologies to The Never Ending Story)
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 02-01-2015, 09:58 PM
DHeal DHeal is offline
If you do use a tail winch be sure to have a fool-proof secondary way to quickly stop the winch in the event that the primary control switch fails in the "On" position. Nothing gets the juices flowing quicker than seeing your pride and joy inexorably being pulled backwards into the T-hangar walls (we came very close one day with our Bonanza).
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
