I’m surprised the vendor suggested cutting the element to change the VSWR without understanding the antenna construction. The antenna also appears to be stripped of the White Powder Coating on the element, did you purchase the antenna this way?
I would appreciate an email identifying the vendor so I can communicate with him.
Based on this mis-information, I will attempt to clarify the types of VHF aircraft antennas and their construction.
Three types of VHF aircraft antennas are used on general aviation aircraft, the Rod Antenna, Pi-Network Antenna, and the Shorted Stub Antenna.
The simple rod antenna was commonly used in the early days of VHF aircraft communication, the antenna consisted of a bent metal rod with a feed thru insulator allowing the antenna to be mounted on the aircraft belly. The co-ax was stripped and the center conductor was attached to the mounting nut. The co-ax braid was grounded to the aircraft fuselage or ground plane.
With most of the activity in the 118 to 127 MHZ range the antennas frequency response was more than adequate to cover the frequency and still have tolerable VSWR.
As the air traffic increased and more ATC facilities came on line, the frequency range was increased to 118 to 137 MHZ. The simple rod antenna proved unable to cover the wider range with reasonable VSWR performance.
Antenna designers went to work and developed matching networks to increase the antennas frequency response and meet the needs of the new wide band transceivers.
The Pi Network and Shorted Stub designs are widely in use today. Examples of the three types are listed below.
Simple rod antenna
http://www.aircraftspruce.com/pages/..._com/av534.php
Pi Network Antennas
http://www.aircraftspruce.com/pages/..._com/av-17.php
http://www.aircraftspruce.com/pages/...m/av10_ant.php
http://www.aircraftspruce.com/catalo.../comant121.php
http://www.aircraftspruce.com/catalo.../comant122.php
http://www.aircraftspruce.com/pages/...om/dmC63_1.php
http://www.aircraftspruce.com/pages/..._com/c63_2.php
http://deltapopaviation.com/VHF_Com_Antennas.html
On the Rod antenna, a shorter element length will increase the resonant frequency, adding element length will decrease resonant frequency.
It is not that simple on the antennas with a built in matching network.
Both the Pi Network and the Shorted Stub antenna performance depend on the inductor / shorted stub relationship to the element length, changing one with out changing the other will degrade the wide frequency response of the antenna.
If the intent is to limit the frequency to a very narrow range, cutting the element length may work out but don’t expect good performance at the band edges.
Checking the antenna installation if fine with a VSWR device to insure it is in the spec the manufacture listed. Both Dorne & Margolin and Comant lists VSWR’s of < 3.0 for the bent element and < 2.0 for the straight element antenna.
Changes to the antenna design and network relationship and expecting wide frequency response out to band edges will require much more sophisticated test equipment.
Keep in mind when testing antennas that the Pi Network designs will show open when inserting a Volt Ohm Meter (VOM) across the BNC connector and the Shorted Stub will show a short.
By the way I’m not aware of any bent element VHF Com antennas designed for general aviation VHF Com that offer VSWR’s less than 1.4 over the entire 118 to 137 MHZ range. If anyone is aware of one, I would like to learn about.
