Old 01-13-2015, 12:16 PM
380mxc's Avatar
380mxc 380mxc is offline
Default Recessed GPS antenna
Has anybody recessed there gps antenna in the glare shield. If so did it have any negative effects.
Tim Emig
RV7
As I hurdled through space, one thought kept crossing my mind - every part of this rocket was supplied by the lowest bidder.
~ John Glenn
Old 01-13-2015, 12:52 PM
krwalsh krwalsh is online now
Default Under the Glare Shield
for the canard builders/drivers it is common practice to put all of the GPS antennae under the glare shield, which is just foam and fiberglass. It is, for all intents and purposes, transparent to the GPS signal.
Kevin R. Walsh
Cozy Mk-IV
Old 01-13-2015, 01:23 PM
gyoung's Avatar
gyoung gyoung is offline
The backup GPS antenna for my GRT is mounted on a shelf under the cowling. I attached my shelf to the firewall but I've seen others attached to the baffles or to the engine mount with Adel clamps. Fiberglass and non-metallic paint won't block the signal. My #1 GPS antenna (for a 430W) is conventionally mounted on the fuselage behind the canopy.
If your -7 is a slider you've got a lot of metal in the roll bar, brace, compass, etc. blocking it on the glareshield assuming inside the windshield. Even worse if you recess it. Sealing is an issue if it's outside the windshield.
Greg
1950 Navion - flying
RV-6 - 18 yrs and 99.5% done
1940 Rearwin Cloudster project next
4 L-2 projects on deck
Old 01-13-2015, 04:04 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Yes you can BUT the antennas still need an "unobstructed view" of the sky. This is means if the glare shield is made of some kind of RF transparent material like fiberglass, foam, plexi-glass, etc. then you should not have a problem.
If your glare shield is made of aluminum then you must make a cut out large enough so the antenna has an "unobstructed view" of the sky.
Either way you should verify that the antennas can "see" from horizon to horizon while still on the ground. Most GPS units can show which satellites it can see in relation to the horizon.
Old 01-20-2015, 08:44 AM
JDanno JDanno is offline
If you have a overhead console it can be put there if the ceiling is fiberglass like the RV10s
