Old 01-12-2015, 08:33 AM
mv031161's Avatar
mv031161 mv031161 is offline
Default Maintenance Tail Stand for Tail Draggers
Question for all Do It Yourselfer,s.
Anyone have any ideas, plans, pictures or link for an tail stand with adjustable height for tail draggers? Need reliable tail stand for Maintenance. I should be able to hung tail freely for maintenance, Level the aircraft perfectly....any ideas will be greatly appreciated!
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 01-12-2015, 08:45 AM
Johnnybgoode Johnnybgoode is offline
Mitch,
There was just a thread within the last couple of weeks with pics of one built from metal and using a come-a-long. I have saved pics at home of a nice wooden one but am in Mexico City so no help now. I'll post them when I get home if no one has linked you to them by then.
Disregard - found them on iPad...
http://i27.photobucket.com/albums/c1...ps498ae2bf.jpg
http://i27.photobucket.com/albums/c1...ps2f1b2c6e.jpg
Patrick
P.B.
Privileged to explore the world in the venerable Lockheed C-130 and the regions around NC in a work-in-progress RV-4, kit #2614, while paying the bills aboard an Airbus A-330.
Old 01-12-2015, 09:06 AM
Smilin' Jack Smilin' Jack is offline
Mitch,
I would used 5 gal plastic pail and put a heavy duty ground stake in it and filled it up with cement
I actually used a wheel axel off a 6 foot mower deck, you can buy the 1/2 screw in stakes that have a screw in plate welded on the bottom they are about a foot long at Home Depot and you do not have to bend anything. NOT THE DOGGIE SPIRAL STAKE
Leave about 3 Inches out side the cement.. IF I did it again, I'd put 2 stakes in about 3 inches apart
When leveling
I take a ratchet strap and loop it around the tail wheel arm and fasten to the 5 gal bucket,and then raise the tail and put it on a couple of padded saw horses which are staggered under the rear bulkheads not under the skin it under a bulkhead in the tail section. With the strap already fastened prevents the aircraft from doing a nose dive into the concrete floor
You might put your prop horizontal and I even put a padded bench under the nose as another precaution when leveling there are several horror stories of the planes going over while raising the tails.
every thing changes level, tire pressure, weight so I shim the saw horses on the rear till I get the plane level.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 01-12-2015, 09:54 AM
mv031161's Avatar
Thanks to all!!!!!!!! I use a 5 gallon Bucket with Speedy Dry now but was looking at something similar what Johnny posted! Thanks again! what you all do for tail wheel maintenance with this type of stand? SMiling Jack..Spot On!
Mitch V.
Old 01-12-2015, 10:34 AM
Mitch since the strap is around the tail wheel arm. To do routine maintenance on the tail wheel is no issue. In fact getting it up to level height help the old back here.
Jack
EAA690
APRS/ WB4JKY
Hunt Aviation, LLC.
Comm Glider
Old 01-12-2015, 10:39 AM
DanH's Avatar
DanH DanH is offline
I don't have my engine assembly stand in use very often, so it spends most of it's time at the airport, converted to a tailwheel stand. Need two feet of 1" all-thread, two nuts, a piece of plate, and a few short lengths of angle to make the wheel cup. Rock solid, fully adjustable for height.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-12-2015, 10:45 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Lots of good ideas and things that work. Search for "Tailmate" to get another one - they are no longer available, but we love ours. It seemed expensive until we thought about what a wrenched back woudl cost.....
You coudl easily make one if you have welding skills.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-12-2015, 11:11 AM
JonJay's Avatar
JonJay JonJay is offline
I use a Tailmate as well. If I am going to have it up for a while, I tie the tail to it and put a board across the bottom weighed down with a heavy vise.
An RV jacked from the wing tie downs will fly the tail even when tied to a stand unless it is weighed down.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-12-2015, 03:29 PM
mv031161's Avatar
Love this design! and that's exactly my assembly! tell me more about those ribs in the floor! whatcha building?
Mitch V.
Old 01-12-2015, 10:44 PM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
Default How much weight?
Just out of curiosity, how much weight is this tail stand holding? I can imagine many wooden or steel ways to hold the tail wheel up, I'm curious the load it's going to bear.
Clay "Cookiemonster" Cook
USAF: T-38, F-111F
American Airlines: 727, MD80, 757, 767, 737
RV8 #81751 project sold
RV8 #81651 project acquired
https://theonceandfutureflyer.wordpress.com/
Donations up to date thru December 2015
"...serenity...courage...and wisdom..."
