[quote=I haven't found a deburring tool that doesn't remove what I consider to be a lot of aluminum. [/QUOTE]
I use a small 100 degree countersink from Avery or Brown, chucked in a battery powered screwdriver, works great, and quickly, as a deburring tool, and it's very easy to precisely control the amount of metal removed. Tried countersinking cutters, and, like you, found that it is easy to cut too much too quickly.
OldSam
RV7A, Empennage, Wings & Tanks complete
Fuse under way
Reason: change dies to cutters
